Question about Electrolux 134743500 Fridgidaire Washer Motor Control Board
I have an old Electrolux washing machine model WH 265 , no letter shown on the selector knob , please if anyone has any advice thank you
JAN_yuanjia
  • 470 Answers
SOURCE: Electrolux EW 1005f washing machine trouble.
try to go for the technician of washing machine, cuz you have the chance to replace it by replacing another board by there old unit that available and compatible to your washing machine
Posted on Mar 31, 2009
  • 3 Answers
SOURCE: Machine stops and the Start light is blinking
It might be teh same problem I have. in my case, teh machine works for a few seconds and then stops i.e. nothing else happens. no alarms go off either. In my case it appears that teh door interlocking device is faulty. You can by this spare part for around 22 euro. Replacing it is a bit tricky because you need to take off the locking device(the slot where the door locks into) and redo wiring. DONT mess up teh wiring becasue then you will need an engineer. Before you go looking for a spare part, you can take off teh interlock adn manual try to operate it. do this by turning on a wash and pressing teh two metal parts together on the lock.
Posted on Aug 27, 2009
mace1mace
  • 1138 Answers
SOURCE: my electrolux EWF 1074 wahsing machine is
Hi!
Posted on Dec 29, 2010
richroth
  • 9472 Answers
SOURCE: Hello there, good day Sir I am currently using one
Press and hold the control lock button for 5 seconds to clear the machine.
Posted on Jan 09, 2011
  • 6277 Answers
SOURCE: I'm finding my electrolux inspire
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 24, 2011
Did anyone can tell me how to enter Electrolux washer Model: EWF1114UW0 service diagnostics mode ?
untitled5-2rgnvy5j4oifscmshudmmeh4-4-0.jpg The procedure is the following:
  • wake up the unit (with door light off and motor stopped)
  • move the knob 2 in the position 1 (for diagnostic mode)
  • press and hold both the buttons 5 and 9.
  • within 5 second the User Interface enters in the test modality (switch on/off led sequence).
  • Turn knob 2 in the position 8 (Last alarm display and possible reset.)
Dado
Jan 15, 2017 | Electrolux Washing Machines
Simpson esprit 550 top loader washer
Have you tried the motor control switch.
Its located below the selector switch.
Its white aprox 5 x 7cm with Electrolux AMD103 stamped in it.
The wires that are plug in it goes to the selector switch.
Apr 30, 2016 | Simpson Washing Machines
How i get off demo mode
Hello Mark, thank you for your inquiry!
I understand that your Electrolux washer is in demo mode and you need help in getting it out of it. In order to get your washer out of demo mode you would need to turn the cycle selector knob to spin only/time dry. Press start then the cancel button. Activate the control panel by turning the cycle selector knob to spin only/time dry cycle. Press and hold the cancel button with the soil level/extended tumble button (third button from the left) for three seconds. This should deactivate demo mode on your washer. If you continue to experience issues with your washer please comment back and reply with your model number. You can locate the serial tag (which lists your model number) on the door frame of your washer. I hope this information is helpful to you. -Matt
Dec 16, 2015 | Electrolux Washing Machines
Model EWF10843. How do I select diagnostic mode?
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position.
10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00
being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
until the LED's stop flashing
Jun 08, 2015 | Electrolux Washing Machines
I have an Electrolux EIFLSS55IIWO Washer. The chrome paint on the selector knob is chipping so Electrolux is sending me 2 new knobs for the washer and matching dryer. Can you please advise how to replace...
Good Morning David,
I see that you are looking to replace the selector knobs for your Electrolux washer, model# EIFLS55IIW as well as your matching dryer. This is typically not a common DIY job, and I do recommend contacting an authorized technician. However, I have found a link on the manufacturers sister website, which I have listed below, that provides a parts breakdown. It will also allow you to enter in the model number of your Electrolux dryer and locate the parts breakdown, as well as, a comprehensive listing of authorized techs in your area. Hope this proves to be helpful!
http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=EIFLS55IIW0&User=&Search=Search
-Best Regards-
WP
Apr 07, 2014 | Electrolux EIFLS55IIW - Front Load Washer...
Washer
Each letter has a cycle length, the bigger the gap the longer the cycle, So it depends on how long you want your underwear washed for, If it is a short cycle turn the dial to the letter with the short cycle and turn it on! Hope this helps.
May 28, 2013 | Washing Machines
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
User manual electrolux WH 3330
How to operate electrolux WH 3330
Jan 05, 2010 | Electrolux Washing Machines
Selector switch knob for kenmore elite washing machine
At the back of the machine are four screws with safety heads they hold the top on. remove them this will give you access to the screws holding that part holding the switch.
Mar 28, 2009 | Washing Machines
Electrolux 134743500 Fridgidaire Washer Motor Control Board Logo
52 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
