Simpson 36s500 the cycle doesn't start properly sometimes, it just makes a noise but doesn't actually works. then you have to spend some time re-setting it (some times 10, 20 minutes) and then the cycle starts properly
SOURCE: Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Posted on Dec 11, 2008
  • 26 Answers
SOURCE: Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Posted on Dec 19, 2008
SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
Posted on Aug 04, 2009
SOURCE: simpson ezi loader washing machine clicks 3 times
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Posted on May 03, 2010
SOURCE: simpson enduro 701 washing machine
you have a faulty brake motor. It pulls in and releases the brake. When pulled right it it contacts a switch which lets the other actions like washing and spinning to occur. $77 to $86 off ebay or appliance stores. turn off ac. remove back off machine. reach around left side of frame at the bottom of the tub and push the brake forward manually and let the little plastic retainer turn sideways and release the wire rope retainer that comes out of the brake motor. remove the power cable to the brake motor by pulling out the connector on the right side under the tub. remove the two 8mm screws retaining the brake motor and remove the brake motor. reverse procedure with new item.
enjoy uninterrupted washes!
Posted on Jun 21, 2010
Hello, My old simpson 175 goes fine upto the spray rinse and then makes this HORRIFIC screaming sound! As its so loud, I dont know if it is actually working but you HAVE to stop it. It sounds like...
Yes sounds like a dry bearing. Belt driven machines can also make a screeching noise if the belt slips. Spray with Belt Conditioner available from auto supply shops. Australian machines a bit problematic for this North American based site. I see manuals listed but nothing that looks like a schematic or workshop manual. There is a link to the Simpson website though.
https://www.simpson.com.au/other/contact-us/
[PDF]User Manual - Simpson https://www.simpson.com.au/globalassets/...manuals/sman_ezisensor_feb12_omo.pdf
  1. Cached
SWT801 and SWT951 Control Panel. Important Safety Instructions ii. 1. Water Saving Technology. 3. Knowing Your Washing Machine. 3. Washing Intructions. 4.
simpson 175 washing machine schematic Google Search
Aug 27, 2017 | Simpson Washing Machines
Hi i have a SIMPSON ESPRIT 600 TOP LOADER WASHING MACHINE. The wash cycle works fine however during the drain and spin cycle, the water wont drain. The machine makes a noise during the drain cycle but...
My guess would be replace the pump, it is normally driven by the motor and if the wash cycle is good the motor is operational. You have to investigate to find the actual part to replace.
Dec 03, 2014 | Washing Machines
I have a Simpson Ezi Set 450 top loader washing machine which doing everything else although it will not agitate, why?
Fairly common issue. Motor control module is shot.
You can get them from your local parts shop, or ebay.
Sometimes they are direct swap by the big plug, sometimes there is slight rewiring required (wiring diagram comes in kit and they are just spade connectors on to the timer, no splicing or anything).
If you take the top panel off and it does not have a module exactly like in the pic on ebay, make sure you are happy to do the wiring bit before buying (easy if you can read a simple wiring diagram)
http://www.ebay.com.au/itm/0628271101-NEW-Simpson-Hoover-Reversing-Motor-Control-Module-GENUINE-/201054721557?pt=AU_ApplianceAccessoriesParts&hash=item2ecfcb9615&_uhb=1
May 26, 2014 | Simpson Washing Machines
Cabrio dryer end of cycle signal doesn't work
We are sorry to hear of the problem with your Whirlpool Dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your Dryer.
Apr 17, 2017 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Hi, I have a 1994 Honda Civic Ex and it won't start. It makes a clicking noise whenever I turn the key. This has been an ongoing problem when I get in the car I have to try several times before the car...
i have a 1992 honda civic hatchback with an 1995 single head vtec motor. the problem with my car is when i go and try to start the car it wont start up right away. instead it makes a clicking noise everytime i step on the clutch and turn the key. my honda is a 5 speed... sometimes it starts up right away but also sometimes it just seems like after 10 to 15 clicks the car still havent started yet. all the lights and everything else comes on fine from what i can see... what else can be the problem or anything that i can do very soon without spending any or alot of money yet???
Aug 18, 2010 | 1994 Honda Civic
Simpson esprit 750
machine stopped moving round --goes through the cycles --the agitater just woun't spin out --makes a humming noise
Nov 01, 2008 | Washing Machines
It's not a Kenmore it actually a Whirlpool Large Capacity, Special Edition
see if you can turn the drum by hand and try again then reply to me
Dec 31, 2007 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
