just changed filter on the 85501 and the filter light will not turn off
Comments:
Apr 25, 2009
- OCCURRENCE The CHANGE FILTER INDICATOR remains lit after replacing the filter cassette.
POSSIBLE CAUSE/SOLUTION Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off
I wired 2HP Dayton AC Induction motor for high speed. internal wires are yellow & red wire...
(More)
I wired 2HP Dayton AC Induction motor for high speed. internal wires are yellow & red wire common connection, blue wire . pin 1 pin 4 for line voltage. motor had same problem, run for a little while stop, then start, then stop. was told wired wrong an burned up motor. motor does not smell burnt. pulley was changed to smaller size. where can i find AC dayton motor wiring?
We have an EnviroSense True Hepa Air Cleaner 85500. You turn it on and it comes on for about a...
(More)
We have an EnviroSense True Hepa Air Cleaner 85500. You turn it on and it comes on for about a second and then immediately shuts itself back off. My husband has determined it may be the motor Do you know where the motor can be purchased or where this item can be sent in to be serviced?
I replaced the air filter for the first time today. The purifier runs now but none of the indicator...
(More)
I replaced the air filter for the first time today. The purifier runs now but none of the indicator lights are working. I can't tell which cycle it's on and the power button doesn't light up even though i hear the unit running. Can't find a manual on line for this.
