Question about Samsung SGH-E900 Cellular Phone
Keypad buttons When all buttons are pressed, nothing happens at all
Same thing with my phone also.Just now received my new phone..
Posted on Oct 04, 2007
SOURCE:
My start button isn't working....I can press the "popcorn" button and it will automatically turn itself on and cook whatever I have placed in the microwave, but nothing happens when I press the "start"...
If it will start automatically without using the 'start' button, the 'start' button must be bad. If the door sensing switch was bad, it wouldn't start at all. It needs a new keypad. The most common cause of a keypad failure is from spraying a cleaner on it instead of using a just barely damp cloth to clean it. The liquid can run down the front of the laminated keypad and get into the bottom and seep up into the lamination....
Nov 03, 2013 | Jenn-Air JMV9169BAS Convection Microwave...
MODEL 139.53975SRT1 1/2 Hp opener will not work with any remotes, I tried to reprogram remotes; pressed learn button, the light next to it came on, pressed button on remote, nothing happened. I cleared...
The correct way to program a remote is to hold the button down on the remote and then press and immediately release the learn button. If this doesn't work your logic board is bad.
Nov 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Cannot get keyless entry to work. Bought new keyp...
That keypad should work with your opener. I suspect the keypad is bad if you have other remotes that work. If not it could be the logic board.
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hi, My keypad does not work anymore, When I press any button on the keypad nothing happens, how can I fix this?
You can try fixing this problem fixing this problem first by pulling your battery out and placing it back in. After this you can try using your keypad once more.
Kind Regards
Nov 15, 2009 | RIM BlackBerry Curve 8310 Smartphone
Nokia 6600 keypad malfunction
TRY THE MANUAL FOUR BUTTON PRESS FORMAT THAT IS SWITCH OFF YOUR FONE, THEN PRESS DOWN *3 THE GREEN BUTTON AND SWITCH ALTOGETHER AT ONCE AND HOLD DOWN TILL SCREEN DISPLAY FORMATTING
Aug 24, 2009 | Nokia 6600
GW9200L Keypad / Diagnostic test shows code 06
troubleshoot whirlpool duet dryer GW9200 Press the start button and the beeper sounds once and you hear a relay trip but nothing happens. Did a diagnostic / keypad tes and the code was 06
Feb 07, 2009 | Whirlpool GGW9200L Gas Dryer
Keypad does not work when I just change a new battery, no light
Make sure the battery is good. anytime you change the battery you need to reprogram the keypad.
Press and release the square button on the circuit board. You then have 20 seconds to input the desired code and press enter.
Hope this helps
Nov 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Problem ok keypad
Hi ankushritu,
Your problem is because of your misplacement towards.. the keypad holders you check for that and if it doesn't happen after your try.. you go on towards a mobile phone service store for a service.... this happens regularly..... al de bes...
Oct 20, 2008 | Nokia 6233 Cellular Phone
Keypad instructions
I can probably help.  What is the make/model of your keypad?
Jul 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Keypad
check tour keybord conector and cable.It will be work fine.
Apr 30, 2008 | Motorola Mobility E398 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
