Question about Boating
1981 4 hp johnson outboard motor wont start, suspect no spark.
5 Suggested Answers
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
  • 154 Answers
SOURCE: Hard to Start & will not stay running
may need carb clean or tune up
Posted on Aug 03, 2009
  • 770 Answers
SOURCE: 1974 Johnson 70 hp outboard, quits on acceleration.
It sounds like your motor is starving for fuel. At an idle, you have adequate flow to keep the engine running. When you call for more fuel...you sputter and quit. Could be a clogged filter or trash in the line or in a jet. Yes you will have some air in the bulb, but not a great deal. You could be sucking air at a hose connection (loosing some prime)...try this, start the engine and slowly accererate, have someone pump the bulb as you accelerate, see if the engine works properly while doing this test.
Posted on Sep 20, 2009
  • 54 Answers
SOURCE: what is the maximum RPM's that I should be safely
I am not an expert for Johnson but with most 2 strokes about 5100.
Posted on Nov 28, 2009
I have a 1981 johnson 75hp charger. blew powerhead so i bought an evinrude powerhead that was omc identical. I have no spark. wiring issues.Thought johnson and evinrude was same wiring?
go google and type in --wiring schematics for johnson outboard motor 75 hp 1981 model --- and see if there is a pdf version for down load
repeat the search but change the name to evinrude and look for a pdf version down load
go to a dealer service center and see if you can get a schematics for each from them
while it can be expected that the wiring should be the same as each brand is made in a different factory there could be a slight difference in the wiring set up that is causing the problem
Aug 09, 2016 | Boating
1981 70 hp Johnson seahorse outboard motor oil mix ratio please
50:1 Ratio One pint of 2 cycle oil to six gallons of fuel.
Dec 28, 2014 | Boating
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
1968 evinrude starflite 100 hp no spark
Some of those had a battery ignition with a short cap and rotor, and some had a magneto which reached down into the bucket. Both had points and condenser like an old car. The cog belt location was critical. 2 teeth off and it would not fire. the key switch was wired diferently for each ignition system.
Jun 19, 2012 | Boating
I have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
i have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
May 06, 2010 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Does an 85 johnson outboard motor 15 hp have
Not ignition points as a set of breaker points as we know it.The timing is set from magnets set under the flywheel.Hope this helps
Sep 02, 2009 | Sport & Outdoor - Others
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Jun 25, 2009 | Boating
Boating Logo
49 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
