Question about Peg Perego Ride On Santa Fe Train
Thomas tank engine ride on wont go around corners
Need all Thomas the Train ride on manuals
Google it, or go to
http://www.pegperego-parts.com/catalog/index.php?main_page=document_general_info&cPath=1_6_7&products_id=44
They are hard to find. Also they are useless for fixing problems. Wiring diagram, parts list (and a link to website that sells them, or eBay) and DIY personality is needed. :-)
Nov 09, 2013 | RC Thomas the Tank Engine
Thomas the Tank engine coupler not holding on the cars.
Check the warranty. If still under, return it. Otherwise find a store that sells small black rubber bands, around 1/2" in diameter. Wrap one around the coupler behind the knuckle. Check to see if the coupler still opens. If it does move the rubber band either forward or backward until the coupler does not open.
Apr 23, 2013 | Lionel (31956) Thomas The Train Set
Need tracks for ride on thomas the tank engine
Ebay would be where I would go for this.
Jan 21, 2013 | RC Thomas the Tank Engine
Water damaged ride on thomas the tank engine.
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 27, 2012 | RC Thomas the Tank Engine
My Thomas the tanks engine ride on won't hold it's
check the charger with a multimeter and make sure that its putting out the correct amount of volts
Jun 09, 2012 | Toys
Hi i have a thomas ride on an i need a replacmen battery and i cant get on anywhere
Try searchig E-Bay I normally manage to find any type of battery I have needed. If not research it on GOOGLE you will be able to find lots of suppliers for batteries. I hope this helps.
Oct 31, 2009 | Learning Curve Toys Thomas the Tank Engine...
Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
May 28, 2009 | Learning Curve Toys Thomas the Tank Engine...
Where do i plug the charger into
The battery is probably located under the seat and will plug in there
Dec 25, 2008 | RC Thomas the Tank Engine
Peg Perego Ride On Santa Fe Train Logo
20 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
