Question about Golds Gym Power 390 Recumbent Bike
Screen is blinking and cant make it stop - Golds Gym Power 390 Recumbent Bike
Why cant I stop the screen from blinking in and out..I get sound..but the picture goes in and out
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 25, 2015 | Televison & Video
Sharp flat screen - TV went black- now just blinking light - when pressing on/off button blinking light won't stop
fault condition light ,
unplug replug power
if still then its detecting a circuit fault you cant fix easy.
Jul 25, 2014 | Televison & Video
I have a plasma lg32lb9d.when i plug it in the red light turns on next to the power button but when i press it it starts flashing green then it stops flashing and stays on but the screen doesnt turn on.i...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 19, 2017 | LG 32LB9D TV
I have a craig mp4 player model CMP616F and i just bought it, charged it, loaded songs and used it 1 time. now when i turn it on a hour glass comes on the screen and blinks and cant do anything else
i had the same problem with mine searched online and found that someone said to let the battery run completely dead, (turn it on and leave it on til the screen stops blinking) that resets it, and then you charge it for 4 (i think) hours. Worked for mine and I hope it works for you too
Dec 31, 2009 | Craig CMP168C MP3 Player
I have a craig mp4 player model CMP616F and i just bought it, charged it, loaded songs and used it 1 time. now when i turn it on a hour glass comes on the screen and blinks and cant do anything else.
i had the same problem with mine searched online and found that someone said to let the battery run completely dead,(turn it on and leave it on til the screen stops blinking) that resets it, and then you charge it for 4 (i think) hours. Worked for mine and I hope it works for you too
Dec 09, 2009 | Audio Players & Recorders
Cant delete folders
You can delete a file by
1.push menu
2.select folder
3.select file
4.press erase once and "delete" will blink on screen
5.press and hold erase to confirm deleting (or press stop to cancel)
Erase All Folders
1.select folder
2.press erase once and "delete" will blink on screen
3.press and hold record for 2 secs.(Folder/All/Delete will flash at the same time)
4.press and hold erase for 2 secs. again to confirm delete
If you want to erase all the files in a particular folder will leaving other folders files intact.
1.select folder
2.press forward repeatedly until "All" appears on screen
3.press erase-"Delete" will blink on screen
4.Press and hold erase for 2 secs. and all files in that folder will be deleted
good luck
Apr 08, 2009 | RCA RP5012 Digital Voice Recorder
My LG 3280 won't let me make certain calls even though I have set no call restrictions. The screen is also displaying "Cannot use...." I have even reset it back to factory defaults and these...
i have an LG3280 its pretty old but not sure if it broke or can be fixed the initial start up screen blinks when the power is on and i cant get it to stop i havnt been able to use my phone because i cant get it to stop. it wont start up all the way it just blinks constantly. taking the battery out, turning it off for a while does not help
Oct 17, 2008 | Cell Phones
Sony projecting tv kp-57wv700
Based on service manual info, it cant blinks 7 times as per symptoms, please count again blinks. It can be 5 times.
If its 7 times blink, Horizontal Deflection stopped in this case. If you want to repair it at your own, please let me know to guide you further but it is necessary you should have knowledge of electronics.
Aug 18, 2008 | Sony KP-57WV600 57" Rear Projection...
Golds Gym Power 390 Recumbent Bike Logo
44 people viewed this question
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Propulsive
Level 1 Expert
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
