I have a hotpoint blue lagoon evaporative cooler vc1000 and i want to know if you fill in the top of the unit
5 Suggested Answers
SOURCE: evaporative cooler not getting water from water line
If you are not getting water to your cooler, check your water valve where is connected to supply line. Check your supply tubing for kinks. Check your float for a bent rod or internal stoppage. Here in El Paso TX we have a lot of lime and calcium in our water that can cause blockages
Posted on Aug 14, 2013
SOURCE: evaporated cooler is not filling up with water
yes ur water pump is not working properly..
ur will have to check it
Posted on Jun 29, 2009
  • 17 Answers
SOURCE: I have just installed a Bionair Evaporative
check the float assembly. wiggle it up and down. is water dripping there? if so, you know water is getting that far, you need to unplug the plugged area.. Also check the water line and ensure no shut-off valves are turned off.
Posted on Oct 27, 2009
  • 3 Answers
SOURCE: Our fan on our brivis evaporative cooler is not wo...
there is a fan insert with a part Number 17517 this insert sits on the shaft of the motor. my fan is working but not blowing so i went up on to my roof and found out that this particular insert is broken (due to a birds nest )
Posted on Jan 29, 2011
I have a Taiwan evaporated cooler, 120 vac 60 Hz 85 w. Does this unit cost a lot of electricity to run, or is it fairly energy efficient
evaporative coolers use a principle of blowing air though a filter that is water moist
the air passing through the water uses a heat exchange process as the water boils off, the air is cooled and so you get cooler air
very efficient in places where the humidity is under 80% but over that the water doesn't evaporate all that readily and so the effectiveness is reduced
basically the hotter the day and the lower the humidity the more efficient they are.
Cheap --yes as it only runs a small motor for the fan and an even smaller motor for the water pump, but you will need a regular water supply some units have a small tank which needs regular filling and others can be connected to the home water supply
it is not an air conditioner , simply an air cooler.
Jun 15, 2015 | Heating & Cooling
I need a manual for a Hotpoint evaporative cooler; model VC1200
Try going to Hotpoint.com, or if made by another and private labeled that should be available, google it.
Companies often publish user, and sometimes even a service manual as a .pdf
Mar 02, 2015 | Heating & Cooling
Sunpentown Air Cooler SF-608R
When you say filled with ice/ water, is it just an evaporative cooler? in which case it is really only a fan. If it is a proper a/c unit, try emptying the bin you have filled up and try again. Most a/c units have a water bin that fills and switches off the unit by a float switch until you empty it and it runs again. Let me know how you get on!
Mike
May 20, 2012 | Sunpentown SF-610 Portable Air Conditioner
Master cool not cooling. Outside air is dry and temp between 100 and 108. Fan working, water pump working. Water pan is full. Water flowing to top of padPad gets wet but only lightly. Air from cooler...
I would bet that the problem lies in what you said about the pad. It needs to be well-soaked for the evaporative effect of the unit to do its job.
You give no model, but if you disassemble the unit (only the top panel) at the water distribution tube and expose it you can see what's going on. Water flow will be minimal.
The tube disconnects from the water supply tube at one end.
Disconnect it and, carefully since it's plastic, clear debris out of the distributor.
If it's like mine, it will have a fair amount of scale built-up in it. Once clear, re-assemble and start the unit.
Jun 28, 2011 | Heating & Cooling
Just purchased a DeLonghi ev200 this afternoon, filled it up with water, switched it on and still not any cooler, if not hotter....please help, what am I doing wrong.
What yo describe sounds like a swamp cooler, which requires LOW HUMIDITY to actually work. The process of evaporation causes cooling.
If your humidity is not low enough, then you actually RAISE the humidity, and that makes your environment more uncomfortable.
The issue sounds like a physics issue and not the unit that you bought.... My thoughts is that if you live in a higher relative humidity area, units like yours should not be sold..... If you cannot actually evaporate, you will not cool.
Feb 20, 2011 | DeLonghi Heating & Cooling
Our fan on our brivis evaporative cooler is not working. The pump to fill it with water is working and the fuse is fine. what else could it be - the unit is on the roof and I can not get to it.
May 17, 2010 | Heating & Cooling
I have just installed a Bionair Evaporative cooler. But when its turned on it will not fill with water. Unit has water connected but unit will not pump it in? Other than that its working fine, fan is...
Oct 27, 2009 | Heating & Cooling
Evaporated cooler is not filling up with water
Jun 29, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Replacing temperature control on a True beverage cooler
Remove the doors, then the evaporator cover. Just be careful.
May 20, 2009 | True GDM-7 Beverage Cooler
Heating & Cooling Logo
186 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
