Question about Ricoh Aficio MP 2000 Black and White Copier
Sc302 charge roller current leak 1027 - Ricoh Aficio MP 2000 Black and White Copier
2 Suggested Answers
  • 393 Answers
SOURCE: sc 302 - charge roller
Replace the PCU assy (drum unit) or a service call to rebuild the unit, sorry...-Carl
Posted on Nov 03, 2010
How do you clear sc 322 and 302 in ricoh mp 2000?
Charge roller current leak
sc302
A current leak signal for
the charge roller is
detected.
1. Charge roller damaged
2. High voltage supply board
defective
3. Poor connection of the PCU
Laser synchronization error
sc322
The main scan
synchronization detector
board cannot detect the
laser synchronization
signal for more than 5
consecutive 100 ms
intervals.
1. Poor connection between the Laser
unit and the BICU board
2. Damaged cable between BICU
and Laser unit
3. Laser unit out of position
4. Laser unit defective
5. BICU board defective
Apr 24, 2017 | Ricoh Office Equipment & Supplies
RICOH MP 2000 ERROR OCCURED SC302
That is a charge roller current leak. A current leak signal for
the charge roller is detected. Possible cause- charge roller damaged or high voltage supply board defective. Check the charge roller first. On the drum, the rubbery roller.
Jul 10, 2014 | Ricoh Aficio MP 1600L Black and White...
Funtional problem SC302
It depends on which Ricoh model.
Some Ricoh copier/printer use a corona wire for charging the drum, so SC302 means that the corona wire is ether broken or have some current leak. but in most case the wire is broken.
Other Ricoh copier/printer use a charge roller for drum charge, so on this model SC302 usually appear when the charge roller have a bad contact.
Aug 19, 2013 | Ricoh Office Equipment & Supplies
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
I have a gestetner DSm745e it keeps on poping out a code SC302 however i don't have a manual for it can you help me?
Charge roller current leak.The polling module detects a current leak of the charge roller.Check,clean or change the charge roller,verify the connection of the PCU,and verify the high voltage suplly board conectors.Turning the main power switch OFF and ON resets the SC code if the error is caused by incorrect sensor detection.
Nov 20, 2009 | Gestetner DSm745 Black and White Copier
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
Mar 19, 2009 | Lanier 5222/27 Laser Printer
Error sc 302
In English:
I would check the roller motor for a short, frayed, or damaged wires. Use a voltometer and compare the voltage to the cleaner motor.
Apr 27, 2008 | Ricoh Aficio CL3500N Laser Printer
What error code 302 ricoh aficion 2016
Hi Manas,
Error code - SC302 is caused due to the leakage in charge roller.
In order to rectify the issue you need to replace the drum and the charge roller .
Nitin
Sep 11, 2007 | Ricoh Aficio 2016 All-In-One Laser Printer
Ricoh Aficio MP 2000 Black and White Copier Logo
42 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
