Question about Ricoh Aficio MP 2000 Black and White Copier
Charge roller current leak for aficio 1027 - Ricoh Aficio MP 2000 Black and White Copier
5 Suggested Answers
SOURCE: I have error code 392 with aficio
SC392 is a problem with your Photoconductor unit (PCU)...could be the density sensor, drum or developer roller not turning. Is it a new unit? Have all the seals been removed?
It could be as simple as a bad connection. try removing and re-installing the unit.
I don't want to necessarily say just order another unit, because the problem could be on the drive of the machine, But it is most likely the PCU itself.
Just a question, when you turn the power off/on, are you using the MAIN power switch (red button)? The button on the control panel will not reset anything.
Posted on Apr 08, 2009
  • 22 Answers
SOURCE: Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Posted on Aug 09, 2009
Digglesby
  • 71 Answers
SOURCE: how to convert ricoh aficio 1027 from german to english?
User manuals are available in pdf from ricoh-usa.com
Posted on Nov 25, 2009
  • 398 Answers
SOURCE: sc 302 - charge roller
Replace the PCU assy (drum unit) or a service call to rebuild the unit, sorry...-Carl
Posted on Nov 03, 2010
Ricoh aficio MP2000 ERROR code SC302.
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20200&code=SC302
Ricoh Aficio 200 Error Codes
Ricoh Aficio 200 Error Codes Code:
Code
SC302
Description
A charge roller current leak signal is detected.
Causes
• Charge roller damaged • Charge high voltage supply board defective • Poor connection of the PCU
Apr 18, 2018 | Ricoh Computers & Internet
RICOH MP 2000 ERROR OCCURED SC302
That is a charge roller current leak. A current leak signal for
the charge roller is detected. Possible cause- charge roller damaged or high voltage supply board defective. Check the charge roller first. On the drum, the rubbery roller.
Jul 10, 2014 | Ricoh Aficio MP 1600L Black and White...
RICOH AFICIO 3025 CODIGO DE ERROR SC 302
High voltage electrical problem:
Charge corona output error - grid voltage error - charge roller current leak.
Not likely to be a diy job.
Apr 06, 2014 | Ricoh Aficio 3025P Black and White Copier
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
Fuctional problems sc402. ricoh aficio 150
SC402: Transfer roller leak error 2
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
  • · High voltage supply board defective
  • · Poor connection of the PCU
  • · Transfer/separation unit set incorrectly
  • · Transfer roller damaged
Jan 26, 2011 | Ricoh Aficio 150 Copier
Sc 302 code error
- Possible causes -
· Charge roller damaged
· Charge high voltage supply board defective
Dec 24, 2010 | Ricoh Aficio 1013F Copier
Sc 302 - charge roller current leak.aficio 1018
Nov 01, 2010 | Ricoh Aficio MP 2000 Black and White...
Error sc 302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
In English:
I would check the roller motor for a short, frayed, or damaged wires. Use a voltometer and compare the voltage to the cleaner motor.
Apr 27, 2008 | Ricoh Aficio CL3500N Laser Printer
When i copy a print i saw code like 302
sc 302 = Charge roller current leak
1 .check charge roller
2.pull pcu out and see that it slots in correctly
3.check for any lose or bend silver plates when pcu is pulled out
Sep 11, 2007 | Ricoh Aficio 2016 All-In-One Laser Printer
Ricoh Aficio MP 2000 Black and White Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
