Lg tv circuit board marquis 1200 - Televison & Video
Tv was on and the picture went out. no picture but i have audio. tv is only 5 months and lg refuse to fix it
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
If the TV is under warranty period, LG is responsible to make it right. It is not a defect caused by you.
Oct 27, 2016 | LG Televison & Video
To know about the circuit board ofmy tv
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Sep 17, 2016 | LG Televison & Video
How do I fix LG LED TV with no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Apr 21, 2016 | LG 50LA6200 50" 1080p 3D Smart TV 120Hz...
LG TV Circuit board
Try www.shopjimmy.com
May 27, 2014 | Televison & Video
My lg tv keeps turning off & on
First of all, thank you very much for choosing FIXYA today for your technical support needs.
Often times this symptom is the result of a failing power supply circuit in your TV, although there are certainly a number of other possible causes.
If your warranty is still valid, then you should definitely contact your dealer / place of purchase and arrange for a refund, exchange, or no cost repair service. If the already warranty is expired, then you have other options available as well.
One fairly easy way to troubleshoot this symptom yourself is to first unplug the set, and then remove the rear access panel on the TV to check the power supply circuit board located inside. Look for any scorched / bulging / leaking electrolytic capacitors on that circuit board. If you see any evidence of this, then you might want to consider replacing the power supply circuit board with a new one, since this is the most often the source of the trouble.
Here are some links to images which show what faulty capacitors often look like:
http://www.facilitateit.com.au/Capacitors.htm
http://www.pctips.org.uk/html/problems.html#Plague
You can usually find replacement circuit boards online by searching for your TV's model number.
Here is a link to a replacement POWER SUPPLY BOARD for your LG model 32LG30 TV currently available on Ebay for about $59 US plus shipping:
http://www.ebay.com/itm/LG-TV-32LG3DC-UA-32LG30DC-UA-Power-Board-EAY40504401-/120732123528?pt=LH_DefaultDomain_0&hash=item1c1c320188
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
The repair / replacement procedure is not extremely difficult if you have some basic electrical safety knowledge and some basic electronics / mechanical repair skills.
You will need to first unplug the power cord from the unit, lay the TV screen side down on something soft and flat like a bed if necessary, and then remove the rear access panel or the entire rear cover as required in order to access the circuit boards inside.
When you remove the rear cover and access the circuit boards inside, just check the part number that is printed right on your currently fitted circuit board, and confirm that it exactly matches the one provided in the online listing. Also make sure that any part you order is labelled "TESTED WORKING" in the condition description. Any part with a condition description of "AS IS" is probably faulty as well.
Then just unclip and remove the various electrical wire connectors leading to the power supply circuit board. Then remove the screws securing the circuit board to the TV frame and then remove the power supply circuit board itself. Be sure to avoid touching any large capacitors on the circuit board which can retain a nasty electrical charge and still cause injury even after the unit is unplugged.
Then just screw in the new power supply circuit board and connect all the wire bundles to their appropriate connectors on the new circuit board and then replace the rear cover. Then plug in the power cord and test out your TV.
If you are not comfortable conducting this level of repair procedure yourself, then you will probably need to contact your local TV repair shop to arrange for service.
I hope that was helpful to you, good luck.
Joe.
Oct 10, 2011 | LG 32LG30 32 in. LCD HDTV
LG TV keeps flashing This function is not available now.
unplug the TV. hold down the power button for 30 seconds. plug the TV in.
this worked for me :)
Apr 06, 2010 | LG 42LC2D 42 in. LCD HDTV
Need wiring diagram for 1984 Mercury Grand Marquis radio
94 radio
Pin Number Circuit Circuit Function 1 296 (W/P) Radio Chassis Memory Power 2 57 (BK) Ground 3 294 (W/LB) 12V Power Feed 4 19 (LB/R) Instrument Panel Dimming 5 296 (W/P) LCD Dimming (Crown Victoria/Grand Marquis Only) 6 694 (BK/LG) Ground 7 448 (O/Y) Radio On Output 8 689 (DB) Logic Mute
Feb 27, 2009 | 1984 Mercury Grand Marquis
LG LWHD 1200 HR Air/Heater fan will not start.
may be a bad fan motor or loose wire, however some units have dip switch settings on the circuit board preventing the fan from coming on.
Dec 19, 2007 | LG BG8000ER Air Conditioner
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
