Question about Brother MFC 210C All-In-One InkJet Printer
Unable to init error message and and machine error 4f
I can scan items and they will transfer to my pc file, but the copier will not copy i am trying to remove this file libbrcompij2 in "/usr/lib" how do i access these files?
I can not print any documents it keeps coming up as Init unable 4f please help ?
Posted on Mar 27, 2014
  • 832 Answers
Please press menu then start mono (b/w) then 4x arrow-up-button. What error code does the machine display? If you have something starting with 4 (except 46: means replace waistinktank) your printhead is crashed and cant be fixed. If there is another code than the above please write here again!
Posted on Sep 27, 2007
I 4f
Posted on Dec 15, 2007
How to fix brother dcp J140 message unable to init 4f?
Error 4f means that your carete is damaged, probable after using not oryginal cartridges, it's reportable but to expensive. If you used brother ink, you can do an complaint I in brother service point.
Feb 16, 2015 | Brother DCP-J140W
MFC-255CW ERROR MESSAGE-INIT UNABLE 4F
Sorry to inform you but 4F is a Main PCB Faulty
Jan 20, 2015 | Brother Office Equipment & Supplies
UNABLE TO INIT. 4F ERROR
This error is associated with the self test the printer does on the print head during power-up of the printer.
Sadly, it is indicative of either a faulty print head or a faulty main control board, neither of which are easy or inexpensive to replace.
Unless you can get hold of another machine with a different fault and swap over the print head and/or board (you'll need very good skills and tools to do this) then I'm afraid the machine is beyond economic repair*.
* Brother will repair your machine but the cost will likley be more than a new one.
Jul 10, 2014 | Brother DCP-330C All-In-One InkJet Printer
Unable to init. 4f in Brother MFC j615w
Sorry to say this error refers to a print head failure. It is not a user changeable part. It will need repairing by a Brother service agent and it will probably cost more than the printer is worth.
Mar 14, 2014 | Brother MFC-J615W Compact Wireless Inkjet...
Unable init 4f
the dcp-130c 3 in one printer not working. message appears on the printer screen is init unable 4f. pliz help me
Jun 22, 2013 | Brother DCPJ125 All-In-One Inkjet Printer
My printer Brother MF 5440-CN inject all in one is unBle print as it show unable init, machine error 4F.
Just checked a site - they suggest that you clear the purge counter, maybe this will help
Feb 29, 2012 | Office Equipment & Supplies
UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Dec 16, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
Init unable 4f
uninstall your printer software under control panel/add remove programs..then reinstall your software again make sure your printer is plug to your pc also...hope this helps..ITTech7574
Aug 31, 2009 | Brother DCP 130C All-In-One InkJet Printer
Unable to Init - Machine error 4f
ok please try this
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Jan 09, 2009 | Brother MFC-425CN Multi-Function Center...
IT will not print.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. OR A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. OR If faxes are present, you can transfer them to another fax machine. Go to Step 3. OR You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. OR To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 01, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
2,988 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
