Question about Joseph Joseph Clip-On Portable Digital Kitchen Timer
How do I put the clock - Joseph Joseph Clip-On Portable Digital Kitchen Timer
How do I reset the time. I put in new batteries but the time is way off
Why not refer to the instructions of the clock? And for most clocks, you can reset time from the buttons in the back of it.
Jun 12, 2015 | Sharp Atomic Weather Station Alarm Clock...
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
HOW TO SET SKYSCAN 86715 ATOMIC CLOCK
first make sure there are fresh batteries in the clock. when you first put the batteries in you will need to look on the clock for the buttons that allow you to choose your time zone., press that button. put the clock in a window or near a wall so that the clock back faces toward Colorado (assuming you are in the united states) colorado is where the atomic clock is located. depending on where you are located you may have to wait till early am (3 to 5 am) to get a strong signal form WWV (the call sign of the transmitter station). you clock should automatically set over night and be ready to go the next morning. you can also manually set the clock, but that kind of defeats the purpose. good luck
Mar 20, 2011 | SkyScan 86709 Atomic Wall Clock
Since DST started I cannot get my radio controlled clock to reset to the actual time. I replaced the battery and now the clock will set itself four hours from the time it stopped, then stop again. i have...
take the batteries back out and leave them out for at least 2 minutes. next put the batteries back in and put the clock near a wall or window so that the back of the clock faces colorado (where the WMV transmitter is),. It will most likely take all night for it to set properly, just after you put in the battery make sure that you have set your time zone on the back of the clock and if there is DST button press that too. just be patient, it will set itself. worse comes to worse you can set it by hand, but kind of defeats the purpose of having an "atomic clock". by the way the reason they call it "atomic" is becausee WMV's clock is tracking the decay of the Seisum atom, or some such bs.
Mar 17, 2011 | Seth Thomas Radio-Controlled Howard Wall...
I have an acurite atomic wall / weather clock but the outside temperature is reading blank. I changed the batteries in the transmitter but still no reading. Where can I purchase a new transmitter. The...
I had one of these a while back and it had a required sequence for putting in the batteries. When the signal dies and you have to replace the transmitter batteries and the clock batteries in a certain sequence. The transmitter batteries cannot just be replaced. You also had to remove the clock batteries, then put in the transmitter batteries, then replace the clock batteries.
Dec 03, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Clock doesn't work. I put in an after market radio
Did the clock stop working immediately after the radio install? If so then it sounds like a fuse may have blown. If not then it is most likely a clock issue. I have 4runner clock removal instructions at my website: www.autoclockrepair.com
Drop me a note if you have any questions!
Mar 29, 2010 | 2000 Toyota 4Runner
I don't know how to make the Ipod go dark after it is on the clok
first set then alarm. then set your ipod lock time to 1 min. you can fine it on your ipod setting. hope i help you.
Jan 11, 2010 | Digital Products International Clok Smooth...
The pendulum stopped swinging...the clock and chimes work well
Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
· Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beat but not always level to function properly.
· Above is the verge with a slip clutch.
· Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
Nov 08, 2009 | Seiko Chiming Pendulum Tambour Mantel...
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Joseph Joseph Clip-On Portable Digital Kitchen Timer Logo
174 people viewed this question
Top Joseph Joseph Home Experts
Donni Steen
Tom Chichester
Are you a Joseph Joseph Home Expert? Answer questions, earn points and help others
