Question about HP Designjet T610 InkJet Printer
I have hp designjet t610,I have replace the NEW MK-Y printhead and it showing me REPLACE FAULTY PRINTHEAD WHAT IS THE POSSIBLE PROBLEM AND IS NEW A PRINTHEAD,is there any way i can bye pass it without show this massage again
websnail
  • 419 Answers
SOURCE: HP L7590 cannot locate printhead latch...don't think there is one
Ok...
The printheads are located in the internals of the printer. To get to them you need to gently lift the control panel up and you'll find this hinges up showing the inside of the printer.
You should then see on the printers LED that you can press and hold the OK button for 5 seconds to change the printheads. Do this until you see the printhead carriage moving out of the parking bay over towards the left.
IMPORTANT: Let the printhead carriage get over to the left and sit for at least 10 seconds before you do anything else as sometimes the printer opts to move the thing after a couple of seconds. Annoying but it can cause damage.. So wait a few.
Once the printhead is all the way over to the left, lift the blue plastic latch/cover from the front and this will reveal the two printheads.
You can now change and/or install your printheads before closing the blue plastic latch/cover and closing the printer lid.
Hope that helps.
Posted on Feb 19, 2009
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Posted on May 01, 2009
ingenito
  • 11 Answers
SOURCE: How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
Posted on Jun 20, 2009
SOURCE: HP Designjet T610
NECESITO UNA SOLUCION PARA MI PLOTTER T610 CODIGO DE ERROR 22.1:10
Posted on Nov 14, 2009
SOURCE: HP Officejet Pro K550 - Printhead Error Message on
I have the same problem. I replaced both printhead cartidges. The MC light stopped blinking, but the KY light kept blinking. I thought it was a faulty new KY ink cartridge. So I returned that cartridge and got a new one. Still the same issue. I called hp and they said the print head is bad now and all they focused on was trying to sell me a new printer. UG! I also heard wiping off the printhead with a dry cloth may help. Did you get yours to wokr?
Posted on Feb 05, 2011
HP DesignJet Z6100 Series - Error "Printhead Replacement Incomplete Restart It"
Time for a new printer. These things are just not worth fixing any more, even many of the large office units are made to break and be scrapped.
Nov 26, 2014 | HP Designjet Z6100 InkJet Printer
Printheads in Designjet 510
Alexander, did you do the allignment after changing print heads?
Feb 01, 2014 | HP "designjet 510 24 in. inkjet printer"
Print head
Update your firmware.
Apr 30, 2013 | HP Designjet T1100ps Printer
HP5500 UV...after paper jam I have a replace lt cyan printhead message and recover black printhead.
The Lt Cyan printhead may have been damaged by the paper jam.
I recommend removing all the printheads and power cycling the machine (turn off then back on) Install the printheads and check that each one says OK. Replace any that show recover or bad. (HP will replace free if it is under warranty - return it to the store you purchased it from)
Nov 15, 2011 | HP DesignJet 5500PS InkJet Printer
1.hp desighnjet 500 showing an exclamation marn on magenta printhead 2. error 59.99 on hp colour laserjet 3700
The exclamation mark means that the magenta printhead is already low in ink or have encounter a problem. Try removing and reinstalling the magenta printhead, if that didn't work, you will need to get a replacement for your magenta printhead since it could be low in ink.
Sep 21, 2011 | Office Equipment & Supplies
Goodmorning, my hp t610 have message print head replacement not complete. I tried several times but the message is always the same. the print head are new!!! I look forward to a response. best...
Hello.
This error occurs when a print head can not be detected. Sometimes the very fine contacts that detect the printhead can become dirty with ink. Power the printer down, remove the heads and try cleaning the circuit contacts on both the printer and the print heads with alcohol wipes. Switch the printer on and replace the heads.
I hope this helps Regards GM
Apr 27, 2011 | HP Designjet T610 InkJet Printer
How do i fix a faulty printerhead for the hp designjet 110plus
are you getting a message failure? fix the printhead how? if the printhead is faulty then you need to replace it. if this does not resolve the issue then you may have a problem with the carriage assembly. clean the contacts of the printhead and the carriage assembly with a damp, lint free cloth (old t shirt works good and water) if this does not help, than your problem is with your carriage assembly, trailing cable, main pca. let me know if this helps, if not than i can help you further
Sep 23, 2009 | HP DesignJet 110 Plus InkJet Printer
HP Designjet 4000ps printhead error
Plz Sir
Stape :: 1
Your Printer Cover Open Few Minitus
Stape :: 2
Plz Chek Your Printer Property .... And Delete Your Own Page
Stape :: 3 Plz Check Printer Property And Port Tab Chenge Selected Port
Enjoy
Aug 17, 2009 | HP DesignJet 1055cm InkJet Printer
HP Designjet T610 InkJet Printer Logo
Seeker5211
Seeker5211
