Question about Hardware & Accessories
Need manual for Defiant 20-Amp 7-Day 7-Event In-Wall Digital Timer
SOURCE: Utilitech 7 day in-wall digital timer #LW60418
Need programing instructions
Posted on Nov 13, 2010
SOURCE: My GE 7-Day Digital Timer model 15086 flashes on
I just bought one today and installed it. It does the same thing - flashes the lights off and on. After some research on the net, it seems that the problem is that an old house is wired with two pole wiring and the new fixtures, (timers included) are 3 pole. The conclusion I have found is that it will not work in a 2 pole wired house. There supposedlly are timers available for 2 pole wiring. I hope this helps. If you find out anything different, please let me know.
Posted on Oct 19, 2009
SOURCE: I HAVE UTILITECH 7-DAY DIGITAL IN WALL TIMER.
Great! I just bought one and am typing the directions from a blown-up scan so I can read them. This us the 3rd timer that doean't seem to want to be programmed and I am forced to operate manually!
Posted on Mar 14, 2010
  • 351 Answers
SOURCE: I bought a Utilitech 7 day digital in wall timer,
HI .. if the switch has only a black and white wire attached, and there are no other wires in the wall box, then you cannot use this timer switch. You need to return it and get a timer that does not use a neutral connection. The wires you have are a switch leg from the light and there is a white wire but it is not a neutral.
If there are other wires in that wall box , tell me and we can chat more about how to remedy this .
Please Vote !!
Posted on May 25, 2010
SOURCE: i have a utilitech 7
You want to install Utilitec in-wall 7-day timer that has 4 wires: red, white, black and green.
You are replacing a single pole switch that controls a light or several lights.
There is not a second switch that controls same lights.
The switch has 3 wires.
Generally there are two insulated wires and a bare ground wire.
Add a comment any time.
Here's what to do:
I have tested these timers for wiring and programming.
Get started and instructions will make sense as you go.
Turn off circuit beaker to switch.
Remove old switch.
1) Timer-green-wire connects to bare ground wire using one of the yellow wire nuts included with timer. Put two wires together so they are even at ends. Put wire nut over wire ends. Rotate wire nut clockwise between fingers until very tight.
2) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire using two more yellow wire nuts. Choose either one for now. You may have to reverse these two wires in a minute.
3) In back of electric box are white wires twisted together and covered with wire nut. Remove the wire nut, but do not untwist the white wires. Connect timer-white to these wires. Then put original wire nut back over white wires.
4) If electric box does not have white wires described in step 3, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires from step 2.
If you need help programming 7-day Utilitec timer. Pages have bigger print:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
Posted on Dec 16, 2010
Lost manual to program defiant daylight adjusting indoor digital timer
videos and text manuals.
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer ...
? 16:31
https://www.youtube.com/watch?v=yxZKNVddNU0
Jun 24, 2015 - Uploaded by Jasco Products Company
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer. Jasco Products Company. Loading ...
Defiant Daylight Adjusting Indoor Digital Timer with Motion Sensor ...
https://www.homedepot.ca/.../p.daylight-adjusting-indoor-digital-timer-with-motion-s... Easily automate indoor or outdoor lights with the Defiant Daylight Adjusting Indoor Digital Timer. Program up to 7 on and off times per week. Auto adjusts to ...
DEFIANT 469-637 QUICK START MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Defiant Manuals > Timer View and Download Defiant 469-637 quick start manual online. DAYLIGHT ADJUSTING INDOOR DIGITAL TIMER. 469-637 Timer pdf manual download.
[PDF]Home Depot Defiant Timer - A-1 Electric Co., Inc.
www.a-1electricco.com/technical/timers/defianttimerprogramming.pdf We appreciate the trust and confidence you have placed in Defiant through the purchase of this daylight adjusting indoor digital timer. Visit us online to see our. defiant daylight adjusting indoor digital timer Google Search
Mar 13, 2017 | Hardware & Accessories
Defiant timer instructions
defiant daylight adjusting digital timer outdoor
Aug 05, 2014 | Defiant Timers: 5-Amp In-Wall Digital...
Defiant 49815 timer user manual
Here is a PDF of the user manual:
http://www.a-1electricco.com/technical/defianttimerprogramming.pdf
Dec 24, 2013 | Defiant Timers: 5-Amp In-Wall Digital...
Defiant digital timer has blinking light
Installed a Defiant light timer today. Light came on as scheduled, but is blinking. When I attempt to "toggle" OFF, it only dims, does not go OFF. When I move the switch from the ON to the OFF position, the unit turns the light off. Defective timer? HELP !!
Aug 14, 2013 | Defiant Timers: 5-Amp In-Wall Digital...
Defiant daylight adjusting digital timer instructions
If you have the Defiant Digital Timer, I found this great video on the Home Depot Website! It's step-by-Step! Nice!! http://www.homedepot.com/p/Defiant-20-Amp-7-Day-7-Event-In-Wall-Digital-Timer-49814/203678179
Jul 19, 2013 | Hardware & Accessories
I am an electrician and my client wants me to reprogram the digital timer (Intermatic) I don't know the model # but it looks like the one on the previous page. Probably the most popular digital wall timer...
Below are links to digital timers to help identify your timer.
Manuals for each timer appear on page.
Programming takes patience, which might be why your customer wants you to do it.
And these 1-year warranty timers go bad, and then timer will not reprogram, which may be another reason why customer wants you to do it.
Intermatic EJ500 and ST01C are battery operated, and will not program if battery is low.
Aube has rechargeable battery that is not replaceable, and this timer will not program if battery is bad.
Other timers shown below have clocks that operate on 120V circuit and require white neutral before display lights up.
Generally each programming is same: You set current time. Some timers you set daylight savings time. Some timers are 7-day, and some offer dusk-to-dawn. For 7-day, you set event1 ON and then event1 OFF for up to 7 programs. You choose the days for each event to operate. Before programming, make a schedule so there are no overlaps or conflicts in programming.
With Intermatic EJ500 and ST01C, event1 is the ON event and event2 is the OFF event, up to 40 events.
Add a comment if you hit trouble spot when programming.
Also fixya offers live phone support for a price.
Intermatic EJ500 with 7-day or dusk-to-dawn
Programming remains in memory forever, so you may only have to re-enter current time.
http://waterheatertimer.org/Flipdown.html
Intermatic ST01C with 7-day or dusk-to-dawn
http://waterheatertimer.org/ST01C-program.html
Intermatic EI500 7-day
http://waterheatertimer.org/Programmable.html#EI500
Aube timers are either dusk-to-dawn or 7-day
http://waterheatertimer.org/Aube-timers.html
Utilitec 0192773 with 7-day and astro dusk to dawn
Utilitec 0141224
GE 15071 - 15086 in-wall timers: one has daylight savings time
http://waterheatertimer.org/GE-timers-and-manuals.html
Woods 59018 in-wall
http://waterheatertimer.org/Woods-timers-and-manuals.html
Tork SS720 in wall:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Dec 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Is this okay to use with CFLs. Cannot find any reference to CFLs in brochure or manual. Intermatic EI600 wall timer
A timer turns the circuit on-and-off just like a switch
Anything a switch can turn on-off, a timer can turn on-off
Things get complicated when using a dimmer, but not a timer
Oct 12, 2010 | Day-Timer Intermatic Ei600c Digital 7 Day...
Need instructions to program Intermatic Model #E140C wall switch timer.
Do you mean Intermatic E104C box-type timer? Intermatic does not make E140C
Manual says "refer to programming instructions on time switch door"
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
Manual says timer has 8 events per 24-hour day ... 4 'on' events and 4 'off' events. Normal operations, selectors are set to AUTO and RUN.
Using sketchy info from manual about programming:
Set sliders to MANUAL & TIME/SET
Press EVENT for event 1 ... set hour and minute using HOUR & MIN buttons ... this will be 'on' time
Press EVENT for event 2 ... set hour and minute ... this will be 'off' time
Set all 8 events ... 4 'on' and 4 'off'
Move sliders to AUTO & RUN for timer operation
Sep 15, 2010 | Hardware & Accessories
Hardware & Accessories Logo
758 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
