Home | Sony | Handycam CCD-TRV37 8mm Analog Camcorder | I have a SONY, model CCD...
Sony Handycam CCD-TRV37 8mm Analog Camcorder
Problem for Sony Handycam CCD-TRV37 8mm Analog Camcorder
I have a SONY, model CCD-FX630 that is dead, how get tape out?
By johnalle on Apr 25, 2009
Hi, I have a SONY camcorder, model CCD-FX630 Handycam Video 8, that has always been lovingly cared for and not used much. When I plug in the AC adapter to the camcorder the adapter's power light turns on bright green but the camera is still dead, I can't get the tape out, I turn on the switch from lock to standby and press the red button to record - no sounds, no motion, nothing. I tried erasing the flat contact points - silver, on the adapter and reattaching to camcorder - nothing happened.
One, how can I get the tape safely out of the camera with not breaking anything?
Two, what is wrong (probably) with the camcorder (an internal battery?) and can I fix it myself?
Three, what and where and how much for the repair of the camcorder?
Thank you very much.
Best regards,
John Allensworth
701-318-3996
jka999@yahoo.com
Comments:
Apr 26, 2009
- I suppose it costs too much to repair. I do thank you much for the useful information.
Best Solution
posted on Apr 25, 2009
Very Helpful)
welcomejee
Rank: Guru  Sony Expert Cameras & Camcorders  Expert
Rating: 89%, 3008 votes
Sony CCD-FX630 is 1994 model and it got problem of leaky electrolytic capacitors on its circuit boards.
Camera needs to replace all electrolytic capacitors on its circuit boards to work again.
Regarding no ejection of tape, this is because video head motor and capstan motor is not rotating ( because of capacitors) and I'm sure power supply in camcorder is not providing proper voltage too.
I been repairing Sony Camcorders since 1992 and have came across many times with this leaky capacitors problem in different models.
If you want to fix camera by yourself, you need to get Service Manual, solder iron to unsold bad capacitors and sold new capacitors, precision screw driver set to apart camera.
You can download Service Manual of CCD-FX630 from Manual Zone for small fee and required electrolytic capacitors can be purchased from HERE. Capacitor image is also there.
Hit "add a comment" button for further query / info.
Thanks.
Popular Solutions for Sony Handycam CCD-TRV37 8mm
Questions and Unsolved Problems for Sony Handycam CCD-TRV37 8mm
Do you recommend Sony Handycam CCD-TRV37 8mm Analog Camcorder?
Answer
Answer
my cam cannot record or play always has a note of insert tape
Answer
tape will not play, it just keeps telling me to eject
Answer
my sony hanycam DCR-HC26 was showing lines in the playback, and now doesnt show anything, like the... (More)
Answer
how to transfer 8mm anaqlog tapes from an old handycam that does not play back any longer
Answer
funciona al momento de ingresar el caseete de gravacion no cierra se abre el porta caseete hay... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Handycam CCD-TRV37 8mm...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
