Question about HP iPAQ RX3700 Pocket PC
Nevomedia server Nevo media server 11 is not compalable with my rx3700.It requires nevomedia 9
0 characters
1 Points
Have a Chinese smart phone and need the detail setup for gprs rogers communication
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to (lowercase), if not work, try ""
8.Edit Username to wapuser1
9.Edit Password to wap
10.Edit Auth Type to Normal
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is and the port number is 80
10.Edit Username to wapuser1
11.Edit Password to wap
Select back or done
Select Activate Account
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is and the port is 80
Edit the Username to
Edit the Password to mda01
Select Done or Save
Make sure to activate the profile and you are good.
Restart the phone.
Internet Settings
USER: wapuser1
PORT: 80
USER: media
PORT: 9203
Mar 01, 2010 | RIM BlackBerry Curve 8310 Smartphone
Need to change the language from portuguese to english.
bro give it to mee then i check it................
Dec 08, 2009 | HP iPAQ RX3700 Pocket PC
Adding hotmail account to my Samsung Blackjack
POP server: (Port 995)
POP SSL required? Yes
User name: Your Windows Live ID, for example
Password: The password you usually use to sign in to Hotmail or Windows Live
SMTP server: (Port 25 or 587)
Authentication required? Yes (this matches your POP username and password)
TLS/SSL required? Yes
Sep 19, 2009 | Samsung Blackjack SGH-I607 Smartphone
Viewsvr 11 what doe s it mean?
The "ViewSvr 11" panic is caused by an application not responding to messages from the View Server for a certain period of time. The View Server assumes that this means that the app has crashed, and hence kills it.
more information can be found at
Jul 11, 2009 | Nokia E61 Smartphone
Firmware Upgrade
yes it is easy just download wmp11 and install it...
it is the matter of windows only
Jun 23, 2008 | ASUS P505 Pocket PC
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to 2. Select "Search" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Sep 15, 2005 | NEC MobilePro 770
IPAQ 3700 Series - Battery not holding charge
In this model of ipaq the battery come inbuilt which means it is not enduser replaceable so cannot place an order to the battery so call HP and send the unit in for service. All the best :-)
Sep 12, 2005 | HP iPAQ RX3700 Pocket PC
Sync Files in Memory Card
Have a look at MightySync....
Sep 11, 2005 | HP iPAQ RX3700 Pocket PC
Media player 9 on ipaq 2215
A hard reset will get it back for you, but you will lose your data. So either backup first, then restore it. Or sync to PC and back if it's just OUTLOOK data.
Sep 11, 2005 | HP iPAQ H2215 Pocket PC
Please help! Cannot sync....
You need to install Activesync onto your PC. Activesync comes on the CD that came with your Ipaq , or the latest version can be downloaded from here... 60-ae11-da92f2b229fa&DisplayLang=en Then from your PC (not your IPAQ), open Activesync, click on File, Get Connected and do NOT cradle the IPAQ until it tells you to. The Activesync on the IPAQ is for wireless syncs, which cannot be done until youu establish a partnership with this first wired sync. You will need a wireless network to do a wireless sync.
Sep 07, 2005 | HP iPAQ RX3700 Pocket PC
HP iPAQ RX3700 Pocket PC Logo
65 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
