Question about Luna Guitars Fauna Butterfly FAU-BTFLY Acoustic-Electric Guitar w/ Stand, Strap, Pick Sampler & Free Acoustic Amplifier Mail-In Offer
I cant turn off my luna guitar - Luna Guitars Fauna Butterfly FAU-BTFLY Acoustic-Electric Guitar w/ Stand, Strap, Pick Sampler & Free Acoustic Amplifier Mail-In Offer
My DigiTech RP355 turns on but only buzzes
Sounds like a classic ground-loop issue. Sound-on-Sound had a great article some time back that may help you.
Apr 10, 2014 | Music
Don't know how to turn on tuner
put a battery in your guitar. It goes in the space at the bottom, usually where you connect your cable to your amp.
Then hold the guitar as you usually would.
Look for a little board with buttons on the side of the guitar to turn on the tuner: )
Mar 27, 2014 | Ibanez Talman Acoustic/Electric Guitar
Cant tune guitar
They have tuners at the Guitar Center cost about 20.00,ask them to show you how to use it and they will be glad to show you, or if something is wrong with the Guitar that it want tune they will check it out too. Any store that carry's Guitars will have tuners.
Dec 03, 2013 | Fender Squier Affinity Stratocaster...
Turning it on?
This guitars turn on when a 1/4 male jack is fully inserted at 1/4 female jack installed on the guitar, also check the guitar female connector for looseness, it should be attached firmly, let me know a bit more to help more...
Nov 03, 2013 | Ovation Applause Series AE148 Super...
I have a Ibanez V Series V70CE. It play well. But sometimes when I connect it to the amplifier, there seems to be loose connection and no sound is heard. When I move the wire little bit sound come...
Many try to use poor quality guitar cables and have the problem. The sleeve of the guitar cable plug turns on the battery in the guitar. Always loop the guitar cable through your belt or the guitar strap to avoid the cable wisting the plug in the guitar causing noise and WEAR that wears the plug sleeve to the point it no longer will activate the guitar.
Sep 18, 2011 | Ibanez V Series V70CE Dreadnought Cutaway...
My boss MT-2 plays is extremely quiet when turned on, the clean channel comes through great, as soon as i turn it on its hardly audible, using the boss power supply, with correct ins and outs, and tested...
It is possible the pedal is DESIGNED to be used with an amplified (preamp within guitar) and yours MAY be a passive guitar. You did not tell us what guitar you have.
Many of the processors for guitars depend on having a "line level" signal and that requires that your guitar has a built in preamp.
If your guitar doesn't have a preamp in it, buy a preamp to put ahead of this pedal.
Apr 28, 2010 | Boss Mt 2 Metal Zone Effects Pedal
I need to output guitar and vocal separately. No matter how I hook it up guitar comes thru the vocal channel
Hi there. Use the "pan" pots to assign the guitar to left channel and all other pans to right channel. Also, turn all effects off or down all the way. (Effects return all the way down.
Thanks
Paul
May 03, 2009 | Digi-Tech Digitech Vocalist Live 4...
Amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Apr 12, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Amplifier is buzzing when i plug in my les paul but ok with other
Several things to try:
- Probably already have, but another guitar cord.
- Ground switch on the amp?
- I had an older guitar that buzzed due to the pickups. While touching the strings, all was well - I was acting as the ground then. The ground wire broke, so it buzzed no matter what. The ground wire ran to the metal bridge.
- Play louder than the buzz! :)
Mar 23, 2009 | Epiphone Les Paul 100 Electric Guitar
Luna Guitars Fauna Butterfly FAU-BTFLY Acoustic-Electric Guitar w/ Stand, Strap, Pick Sampler & Free Acoustic Amplifier Mail-In Offer Logo
19 people viewed this question
Top Luna Guitars Music Experts
Vito Vacirca Jr.
Are you a Luna Guitars Music Expert? Answer questions, earn points and help others
