Question about Lag T200 DCE Acoustic Electric Guitar
Battery change how do i change my tuner battery on my guitar?
Don't know how to turn on tuner
put a battery in your guitar. It goes in the space at the bottom, usually where you connect your cable to your amp.
Then hold the guitar as you usually would.
Look for a little board with buttons on the side of the guitar to turn on the tuner: )
Mar 27, 2014 | Ibanez Talman Acoustic/Electric Guitar
How do I change the battery?
Most there is a little release right by the tuner EQ that allows the tuner with battery box to tip out to replace.
Sep 05, 2011 | CF Martin 000X1AE Java Mahogany Acoustic...
Hi i recently bought a Takamine EG 260c G Series acoustic electric Guitar with TP-4T preamp installed in it. Now the problem is when i connect my guitar to an amplifier, the sound comes through it only...
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
May 02, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
No power to the on board pre-amp tuner. Red light does not come on. Changed batteries with known good ones.
does the guitar still make noise when hooked up through an amplifier? Check for rust or buildup on the battery connections. If necessary, carefully clean the connections with fine sandpaper or a wire brush.
Mar 15, 2011 | Washburn WD10SCE Cutaway Acoustic-Electric...
Brand new chromatic tuner tu-3 pedal, plugged guitar into input and it powers on. Guitar plays through the amp, but when I hit the footswitch the check light and tuning bar do not light up.
Change the battery first. It could be dying and just barely have enough power to come on at first, but not to do anything else. If that doesn't solve it, you've got a defective one and you can go exchange it.
Feb 24, 2011 | Roland Boss Tu-3 Chromatic Tuner Tu3...
Hello, I have found that Ibanez AEL20 guitars' 5AEQ45F (SRTn) preamp-tuner has a 6V voltage, my AEL20 guitar came with 1,5 V batteries (3V in total). There is no internet source to get the...
There is little data on the internet about this... However my AEL20E uses 2 AA cells. Some older ones may have used a 9 volt battery. Yours should use the 2 AA cells which go into the box right by the XLR output plug.
Feb 16, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
My guitar is great I love it but the built in fishman isys tuner is not tuning my guitar properly and when it tells me my guitar is in tune it is really not at all. Is there a way to fix this ? Please...
Hey There,
If its adjustable its worth checking if the Pitch of the tuner is set right (normaly changed by a + & - button) Any normal tuner should be set to 440 which is standard Pitch.
Hope this is of any help
Jan 10, 2011 | Washburn NEW PRO WASHBURN ACOUSTIC GUITAR...
My tuner shows a green flashing light, the battery is new, even checked it with another one. No matter what i do it just shows a green flashing light. picking the strings for sounds makes no difference at...
Often, the flashing green light indicates that the tuner is NOT receiving a signal and is a warning that the tuner is turned on.
First thing is to check if you have normal output from the guitar from the pickup. If the output is normal, there MAY be a failure in the tuner.
ALSO, just because a battery is new doesn't mean the battery isn't depleted... either try another from a different batch or use a voltmeter to check it. I have seen people chasing their tails due to a brand new bad battery.
When you select the tuner does the audio OUT of the guitar cut off as it is supposed to?
Sep 03, 2010 | Washburn D10sbc Acoustic Guitar
Lag T200 DCE Acoustic Electric Guitar Logo
14 people viewed this question
Top Lag Music Experts
Vito Vacirca Jr.
Are you a Lag Music Expert? Answer questions, earn points and help others
