Question about Power Acoustik PTID-5800 Car Video Player
Dash light illumination wire - Power Acoustik PTID-5800 Car Video Player
2003 XKR dashboard illumination goes off when main lights switched on or if dash lights do stay on after starting they go off when main beam is operated.
is this car the all alluminium xk model ? if so it sounds like a bad earth the earth studs are all bonded to the body and are prone to detatching from the body and causing all strange probs. the favorite ones are both front behind the wheel arch liners, if its the older xk still sounds like a bad earth poss behind the headlamps. the only other probs i had was wires coming detatched/poor connection from the column switch, hope this helps
Oct 03, 2016 | 2003 Jaguar Xkr
No high beams on multifunction switch and now dash illumination light
check the relay's incoming wire from the light switch. I suspect the actual switch is faulty as you have also lost the dash lights .
If no voltage arrives to the relay coil there is a good chance it is the actual switch.
had this happen to one of my cars and had no headlights at all and no dash board illumination and it was the switch.
Mar 30, 2016 | Cars & Trucks
Got a 98 k1500 4wd changed the turn indicators on the pass side one was out and the other broke front of truck put the wrong bulbs at first and all lights flashed.. checked the number on the other side put...
There is a small fuse in the cab fuse block ,for the insterment panel that is verry easy to miss if you don,t look close ,it is hidden kind of at the top of the fuse block behind the wires,
Nov 29, 2012 | 1998 Chevrolet K1500
Left headlight, dash lights, and both tail lights do no illuminate. brake lights and high beams work fine. what would cause this to happen, fuses are good.
Most certainly a wiring fault, you need a wiring diagram, these items are related as in all on same circuit. Check rear of fuse box.
Feb 20, 2012 | Hyundai Santa Fe Cars & Trucks
Can the orange/white illumination wire from the factory plug be tied into the red or yellow wire? My harness does not have any other available wires.
the illumination wire is for your dash lights so you can dimm the light on your deck. your best bet would be to go to the car audio store and buy a wire harness for 15$ this will convert your in dash factory plug to an after market plugg for your deck.
Jan 30, 2011 | Car Audio & Video
I have a honda odyssey 2001 the light of the panel are not workinkg all the rest of the lights are working i check the fuse and are ok only i did was change the radio and install a new one but did not...
I'm guessing you're talking about the dash light aound the radio. The dash lights around the radio share the same fuse with all the other lights that come on when you turn the parking light on. If the other light are working then your fuses are fine. What i think might have happen was when you took the dash cover off, the bulbs behind it might had burn out. You might want to try new bulbs.
good luck
Jan 20, 2011 | Honda Odyssey Cars & Trucks
Aftermarket double din install having problems with int. dash lights,locks
I had soved my problem... That was stupid.. The cause is that I tried to connect the (illumination +) and the (illumination -) wires togetter on the dimmer wire of my double din unit. That make a short cut and blow the litening fuse (fuse 13 on passenger side fuse panel). I replaced correctly the wiring, keeping the (illumination +) wire unused. That solve my problem but, however I get back my dash illumination, I can't adjust the lightning level... I thing I have a problem with the level switch.. It don't matter to me but if you get the same problem and solve it, please tell me your solution.
Regards
jerome
Jun 02, 2009 | 2001 Acura 3.2CL
Illumination?
you need to splice the + wire into the Acc wire. the with power only when you turn the key. and the - wire into the black ground wire. hope this helps
Jan 29, 2009 | iLO XM-MP3-CD Car Stereo
Power Acoustik PTID-5800 Car Video Player Logo
20 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
