Question about PfaFF Creative 7570
How can i get pfaff creative suite version 6.2 download to window xp. ? doesn't find the dongle when plugged in?
  • 8 Answers
SOURCE: threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
Posted on Feb 14, 2008
SewExpress
  • 41 Answers
SOURCE: Pfaff Creative Customizing
Good morning,
Hoping I recall all the steps (worked for Pfaff for 10 years doing just this type of thing but found there were a lot of variables and was never able to write them all down in one place!)
If the following doesn't work, send me your phone number and I'll be happy to call and try to walk you through getting it re-installed (kim@sewingexpressions.com)
Here goes:
  1. Uninstall your Pfaff software program (either through Windows Add/Remove Programs or with the Pfaff Uninstall feature)
  2. With the dongle still connected, right click on My Computer, selectProperties, select Hardware tab, select Device Manager (assumingWindows XP if earlier version you won't see Hardware Tab - just selectDevice Manager).
  3. Locate the dongle under Universal Serial Bus Controllers (will be listed as Rainbow, Sentinal or Aladdin depending on version of dongle)
  4. Double-click the listing for your dongle, click the Driver Tab, select Uninstall. This should remove all traces of the dongle software that was previously installed.
  5. Remove dongle and re-insert in USB port. This should automatically trigger the dongle install.
  6. After dongle re-installs, right click on My Computer, select Properties, select Hardware tab, select Device Manager (assuming Windows XP if earlier version you won't see Hardware Tab - just select Device Manager).
  7. Locate the dongle under Universal Serial Bus Controllers (will be listed as Rainbow, Sentinal or Aladdin depending on version of dongle).
  8. Double-click the listing for your dongle, click the Driver Tab, select Update Driver.
  9. Make sure you're connected to the internet. A window will open - select Yes, This Time Only & follow prompts to attempt to locate newer driver. This will attempt to find the most current driver for the dongle. Depending on the version of the dongle software on your computer, it will either find a new version or tell you there is no newer one. If a newer driver available, allow it to install.
  10. Once you've finished the above to update dongle driver, close all the open windows.
  11. FINALLY, you should be able to install your Pfaff program...with no problems. LEAVE THE DONGLE INSERTED when you reinstall your customizing - even though the program tells you not to.
Rather tedious but it is necessary to remove as many traces of the previous install as possible (program and dongle drivers) before reinstalling. The key seemed to be installing the dongle BEFORE the Pfaff program, updating it and making sure it worked before trying to install Customizing.
As I indicated before, if this doesn't work, I'd be more than happy to try to walk you through - just send me a phone number and a time that would be convenient.
Crossing my fingers,
Kim
Posted on Jul 16, 2008
azach
SOURCE: Pfaff 7570 connection to new XP laptop
In this FAQ list (from PFAFF web) you find 100 times the same question and answer:
H402 My new computer does not have any serial COM ports, so how does it communicate with my Pfaff creative 7570?
You will need to obtain a USB Serial Adapter, which adds a serial port to your computer by plugging it into a USB port. Suitable adapters can be obtained from Belkin [http://www.belkin.com] and Keyspan [http://www.keyspan.com].
The following USB Serial Adapters are known to work with the Pfaff creative 7570:
• Belkin F5U103
• Keyspan USA-19QW
Please note that the Belkin F5U109 is listed as working with the Pfaff creative 2140/2144 (FAQ #H405), but it does not work the Pfaff creative 7570.
Posted on Jan 15, 2009
  • 1015 Answers
SOURCE: Need PC Designer for for 750 windows xp/where?
If you purchased the software after April 1st,2006 then you will be entitled to a free upgrade. If not you might have to purchase the software. Here is a link to the PFAFF software download page. http://www.pfaff.com/global/11283.html
Posted on Nov 13, 2009
  • 5 Answers
SOURCE: connect PfaFF Creative 7570 to a PC
The software you need to connect the Pfaff 7570 to the PC and to create your designs is called PC-Designer version 2.2 from Pfaff. You may be able to find a used copy. The software should come with a dongle (special cable) for connecting the machine to the PC. Make sure you have this piece because it will not work with an ordinary cable. Depending on what type of port you have on the PC to connect to, you may also need an adapter since the dongle has an old style connector on the end going to the PC. If you are going to create your own designs, you will also need a storage card which inserts into the machine that you send the designs to. Pfaff makes one, called the creative card. I have also used a generic card meant for the pfaff; the generic card is less expensive and has a greater capacity. You can find many designs online either free or for sale to send from PC to Pfaff as well.
Posted on Dec 15, 2009
How can I get my Pfaff 3d embroidery software to work with windows 7? What do I download for the dongle also?
The only solution I've ever heard of is buying an older machine that has XP....
Jul 18, 2012 | PfaFF Sewing Machines
I have a Pfaff 7570 with Windows 7 professional. Windows 7 has a special program that allows you to use programs with windows XP. I have everything installed properly but can not get any communication...
I can't tell you much or offer any advice but I can tell you with absolute certainty the Windows 7 compatibility programme has never worked for me.
I have stuff I used to use with XP and either it works with 7 or it doesn't and if it doesn't the compatibility programme makes not a jot of difference.
Nov 11, 2017 | PfaFF Creative 7570
Dongle for sewing machine can't be activated
It could be you need a new software program or patch for the newer version of Windows.
Check with your dealer.
Mar 21, 2010 | PfaFF Creative 7570
Connect PfaFF Creative 7570 to a PC
Nov 27, 2009 | PfaFF Creative 7570
Nov 13, 2009 | PfaFF Creative 7570
• Belkin F5U103
• Keyspan USA-19QW
Jan 06, 2009 | PfaFF Creative 7570
Good morning,
Here goes:
Kim
Jul 12, 2008 | PfaFF Creative 7570
Sewing Machines Logo
202 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
