Question about Sealy Electric Mattress Pad
Display reads E when turned on - Sealy Electric Mattress Pad
How to reset the meter counter after replacing the fuser assembly on hp8150 laserjet printer.
Here is the step by step guide to resetting that message.
Reset the "Pages Since Last Maintenance by using this procedure:
  1. Turn off the printer.
  2. Hold down the left side of the ITEM and VALUE keys at the same time.
  3. Turn on the printer.
  4. Wait for RESET MAINT\\COUNT to display, and then release the keys.
  5. Allow the printer to initialize normally. The display will read "READY ".
Turn off the "PERFORM PRINTER MAINTENANCE message by following these steps:
  1. Press the MENU key until the display reads CONFIGURATION MENU .
  2. Press the ITEM key until the display reads MAINTENANCE MESSAGE=ON .
  3. Press the -VALUE+ key once. The display should read MAINTENANCE MESSAGE=OFF .
  4. Press the SELECT key to put an asterisk by the setting and save it.
Mar 18, 2013 | HP LaserJet 8150 Printer
My 2006 C280 was due for service B , and I just did the oil change only. How can I reset service B message on the car computer ?
Reset process should be listed in the owners manual.
Should be something like turn car to on(not running) press trip button twice, turn to off and hold trip button till it resets.
Apr 19, 2010 | 2007 Mercedes-Benz ML320 CDI
How can I check the compressor relay? Is there a way to check and see if it's working?
If it rattles when you shake it it's bad.
There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.Test the compressor relay for continuity using a multitester. Set the multitester to the ohms setting X1.
With the relay upside down, place the probes into the terminals labeled "S" and "M". The multitester should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up).
With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The multitester should now display an ohm reading of infinity (or the tester should not light up).
Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L".
The multitester should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity.
With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M".
The multitester should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms.
If the compressor relay does not pass all of these tests, it should be replaced.
Mar 03, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
When i changed oil i forgot to follow the corect proceedures,so now i reading in dashboard of my car . change oil soon . later i follow the proceedures in cataluge , but same sentence appear pls. advise
this light is triggered only by miles. you will probably need to go to the dealer to reset this light. in the meantime try this: 1. Turn the key to the "ACC" position which is the notch that allows power but doesn't turn the engine.
2. The display will read change engine oil soon - hit the display button(i) and the display will read 0% oil life.
3. Hit reset button (the check mark button) for 5 seconds and the display will change to 100 % oil life.
4. It may not work the 1st,2nd,3rd .... attempt , but will work eventually.
Nov 09, 2009 | 2007 Suzuki XL-7
How do you turn off the demo on the jvc car radio
Hello gusjandreau,
Press and hold the SEL button until the receiver enters the PSM mode (until the display changes). Use the left/right rocker switch until the display reads DEMO. Turn the volume knob until display reads DEMO OFF. Briefly press SEL to exit PSM mode.
Hope this helps.
Jul 22, 2009 | JVC Ks-U58 Input Adapter To Stereo Mini...
The display reads ring off. how do i turn on.
Hi
The ring is "Off" when the volume is turned down to zero
Turn the ring volume up and it should go off
Jun 19, 2009 | Panasonic KX-T7431 Corded Phone
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
Printing issue
In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
Procedure to save your current printer settings
Procedure to restore printers original factory settings
Procedure to restore your saved printer settings
1. Make sure the Online light is lit and that the display reads Idle.
2. Press the Online/Offline button to take your printer offline.
3. Press the Menu button once. The display should read Operator Control.
4. Press the Right Arrow button once. The display should read Administration.
5. Press the Select button once. The display should read Communications.
6. Press the Left Arrow button until you see Miscellaneous in the display.
7. Press the Select button once. The display should read Save Defaults.
8. Press the Select button again. The display should read No.
9. Press the Left Arrow button once. The display should read Yes.
10. Press the Select button.
11. A few seconds should pass until the display reads Yes Is Selected.
12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
6. Press the Left Arrow button until you read Miscellaneous in the display.
8. Press the Right Arrow button. The display should read Restore Defaults.
9. Press the Select button once. The display should read Factory Defaults.
10. Press the Select button again. The display should read No.
11. Press the Left Arrow button once. The display should read Yes.
12. Press the Select button. Yes Is Selected will appear in the display.
13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
14. Your printer will reboot with the original factory settings and return to Idle.
Try a test print. Does the problem still exist?
10. Press the Right Arrow button. The display should read Custom Defaults.
11. Press the Select button. The display should read NO.
12. Press the Left Arrow button once. The display should read Yes.
13. Press the Select button. Yes Is Selected will appear in the display.
14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
Try a test print, does the problem still exist?
Sep 24, 2008 | Minolta magicolor 3100 Laser Printer
Sealy Electric Mattress Pad Logo
52 people viewed this question
Top Sealy Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Sealy Furniture Expert? Answer questions, earn points and help others
