Question about Home
Angeleye smoke alarm keeps chirpping - Home
4 Suggested Answers
  • 188 Answers
SOURCE: it is a direct wired smoke alarm and it keeps
Replace the battery with thew exact model specified.
Posted on Aug 07, 2009
  • 11 Answers
SOURCE: smoke alarm keeps chirping
I am having problems seeing if you have any more data besides "smoke alarm keeps chirping." so I will ask; have you tried changing the battery?
Posted on Sep 06, 2009
  • 4736 Answers
SOURCE: Our smoke alarm with battery
You didn't mention if you had replaced the battery, yet. If you haven't, then that's more than likely the problem. Also, it probably needs cleaning. You can accomplish this by using canned compressed air (like you clean your computer with). Use the straw nozzle to reach all the nooks and crannies. Clean after removing the old battery and before installing the new battery. Batteries should be changed annually and at the same time clean the unit. When using the canned compressed air, try to keep the can in the upright position, as much as possible.
Posted on Jan 25, 2011
Alarm chirps replaced battery still chirps what is wrong?
Hello, Jim -
I hope I am correct in thinking you are asking about a home smoke alarm. If so . . .
Read the article here which lists many reasons as to why a smoke alarm may still chirp after the battery has been replaced:
http://www.wirechiefelectric.com/blog/resources/what-to-do-when-smoke-alarm-keeps-beeping
If I am incorrect in thinking your question is about a home smoke alarm, please choose Comment and state what kind of alarm you are asking about.
Best wishes.
Apr 19, 2018 | Home
MY ALARM KEEPS CHIRPING. Thought I should change the battery but discovered it's not battery operated!
A chirping smoke detector indicates low battery! Change battery or replace smoke detector!
Aug 15, 2015 | Home
My Kidde Model 1285 keeps chirping even after I changed the batteries, any ideas why?
Be sure you are using a well known brand battery. The store brands, in my my opinion generally are not quite up to par. Try this and see if the chirp will stop. Thanks for asking me.
Dec 21, 2014 | Kidde 1275 Hardwire Smoke Alarm with Hush...
My kidde AC smoke alarm I12020 chirps at night then come daylight it makes no noise
Most "chirping" is indicative of low batteries. Perhaps your smokes are improperly wired through a light switch? As to locating, try using a piece of tape over the sound port to change the sound; with these problems there are often more than one causing it. Check also to see if you have any CO alarms that were plugged into a switched outlet. Most of these also have battery backup. Good luck!
Mar 08, 2013 | Kidde Kiddie Ac Wire-in Smoke Alarm I12020
Rental mgmt company just installed Kidd 112020/40/80 (don't know which one. It does the same thing the previous smoke alarm did - wakes me up in the middle of the night! It chirps every hour, every 30...
They only chirp for two reasons:
1. The sensor is past its useful life and needs replaced
2. There is a power issue with the battery. Even the ones that are hardwired into the electrical system need a battery.
Jun 23, 2017 | Kidde Kiddie Ac Wire-in Smoke Alarm I12020
Smoke alarm keeps chirping. put in new battery and continues
The sensor inside can go bad and that is not repairable...
you may need to replace the smoke alarm..
heatman101
Sep 05, 2010 | Vacuums
Replaced 9 v batteries, units still chirping
This is the troubleshooting information from the kddie site. The problem is usually related to an older battery or improperly installed battery. You might also have to do a reset as described below. If battery and cleaning don't work, it might be time for a replacement - short money to keep you and your home safe.
  1. The battery may be loose, or improperly installed.
    Verify that a battery of the recommended type is securely installed. Make sure to use a battery with a use-by date no later than four to five years in the future. Check that the battery is snapped in completely so it cannot be shaken loose. It’s possible that battery connections may not be making good contact with the battery. Disconnecting and re-connecting the battery once or twice will likely fix this condition. On units with a front-load battery, be sure that the battery compartment door is closed completely as well. Loose white neutral wire can cause an echoing chirp. (From one unit to the next)
  2. The smoke alarm sensing chamber may be dirty.
    Dust and insects can collect in the sensing chamber of the alarm. An accumulation of dust in the sensing chamber can cause the unit to chirp. It is good practice to clean the smoke alarm when you change the battery. Static electricity from the ac quick connector attracts dust and can cause false alarms.
    Cleaning smoke alarms:
    To clean your alarm, remove it from the mounting bracket as outlined here. You can clean the interior of your alarm (sensing chamber) by using compressed air or a vacuum cleaner hose and blowing or vacuuming through the openings around the perimeter of the alarm. The outside of the alarm can be wiped with a damp cloth. After cleaning, reinstall your alarm, verify the green LED is on and test your alarm by using the Test Button. If cleaning does not restore the alarm to normal operation, the alarm should be replaced.
  3. Check environmental conditions:
    • Humidity, steam and condensation can cause false alarms. Causes of condensation are:
      • Extreme temperatures changes.
      • High ambient humidity.
      • Unit being installed in an uninsulated electrical box mounted on a ceiling beneath an attic. If this condition exists you’ll want to move the alarm. Click here to see the correct alarm placement in your user’s manual found in our Download Center.
    • Check to see if there is a cooling/heating register, a ceiling fan or an open window within 3 feet of the alarm. If there is, move the alarm away from the source of the increased airflow. Click here to see the correct alarm placement in your user’s manual found in our Download Center.
    • Check the temperature of the room. Smoke alarms operate at 40 degrees to 95 degrees Fahrenheit. Carbon monoxide alarms operate at 40 degrees to 100 degrees Fahrenheit.
  4. Reset the alarm.
    Some current model smoke alarms have a processor that retains certain error conditions, such as a weak battery. The error condition should reset when the battery is replaced but sometimes it does not and must be manually reset to clear the error.
    To reset an AC unit with a battery backup:
    Turn off the power to the smoke alarm at the circuit breaker.Remove the smoke alarm from the mounting bracket and disconnect the power. Remove the battery. Press and hold the test button for at least 15 seconds. The unit may chirp or alarm for a few seconds before going silent.Reconnect the power and reinstall the battery. The unit will chirp once when the power is restored and should not chirp afterwards.
    To reset a DC only unit:
    Remove the battery. Press and hold the test button for at least 15 seconds. The unit may chirp or alarm for a few seconds before going silent.Reinstall the battery. The unit will chirp when the battery is first connected but should not chirp afterwards.
  5. An electrical condition may be causing the power to the unit to be interrupted.
    If the AC power to the unit is interrupted, the unit will chirp when the power is restored. This could be caused by power surges.
    If the chirping seems to occur at about the same time in the evening or morning, it could be due to a surge created when the power company switches electrical grids to meet demand. Check to see if the chirp (or chirping) occurs when something else in the house is turned on such as an exhaust or attic fan, a heater, etc. If the smoke alarm is connected to a circuit with such a device, the alarm may chirp when the other device is switched on. If this is the case and the device is plugged into a wall outlet, move it to another outlet on a different circuit. If it is a hardwired device, have an electrician investigate it. These conditions can be minimized by installing your alarms on a dedicated circuit in compliance with NFPA requirements.
  6. Replace the alarm.
    If none of these conditions exist and the suggestions don't alleviate the symptom, the alarm should be replaced. Age may be a factor. Smoke and heat alarms should be replaced every 10 years, and carbon monoxide and combination alarms should be replaced every 7 years. Most of our alarms have a 5 year warranty from date of purchase (check your user manual for details). A date code is stamped on the label attached to the back of the unit.
Feb 02, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
My alarm and smoke detector keeps beeping a single beep every few minutes
Ours keeps chirping even after we replaced the battery. I'm not sure how to fix it.
We are going to try and clean it but if it keeps doing it after that then I guess it means it needs to be replaced, right?
Nov 26, 2009 | Kidde 120-Volt Front Load Battery Smoke...
Sep 06, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Home Logo
47 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
