SOURCE: my new washer did not spin out the water
if its a new washer call and have them trade it out for another one.
SOURCE: samsung front loading washer, New, model WF218AN
IF IT IS NEW YOU SHOULD CALL FOR SERVICE. SAMSUNG HAS A 1 YEAR WARRENTY. IF YOU ARE USING HE SOAP AND NOT TOO MUCH YOU SHOULD CALL FOR SERVICE
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: long spin cycle of my Samsung WF8590NHM Front Load
Hi.
The error code is not 5D but SD, which means slow drain detected.
Check drain hose. Check drain filter attached to the pump. Check pump itself and pressure switch.
Regards.
Ginko
SOURCE: samsung vrt front load washer will not spin out, ( not working)
I have the same washer and mine wouldn't spin out all the way sometimes leaving the clothes very heavy and wet. My problem was that the drain hose from the washer that you put inside your drain pipe had created a suction preventing it to drain properly. It might be worth checking. I know for forking out so much money on the thing it sure can be finicky.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
heatman101
