Question about Samsung HT-Q100 System
Have a circle with a line through it and cannot connect to my wi fi system
  • 3 Answers
SOURCE: Connection to wifi internet
Try a new partnership with your pc and and use active syn to update your phone.
Under connections you'll find wi-fi in theresomewhere and choose it as default connection and you should be good to go.
Hope this els,
Steven John
Posted on Nov 30, 2008
tinualbinale
  • 436 Answers
SOURCE: Im connecting to my home WI fi and it says authentication failed
You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
Posted on Sep 12, 2009
  • 630 Answers
SOURCE: samsung BD p3600, can not connect to the Wi Fi
Forgive me if you know this already IP address needs to be different to the Apple one. If the Apple one is 192.168.0.1 make the Samsung 192.168.0.2. subnet 255.255.255.0. Gateway should be the same as the apple number.. DNS can be left to automatic but if stuck use 4.2.2.3. Check the security settings on both the Apple and the Samsung are set to the same type
Posted on Oct 11, 2009
gomartymo
  • 20 Answers
SOURCE: could not connect to the internet using wi-fi connection
need to configure modem/router. just put ip address off modem into address bar on web browser. use admin as name and password for password. Check out portforward.com and all info will be easily found to solve problem.
Posted on Oct 26, 2009
darkpain
  • 316 Answers
SOURCE: I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
Posted on Jan 08, 2010
How do I set password on Wi-Fi orca android tablet
Answer Line: Change your Wi-Fi password on various ...
www.pcworld.com/.../change-your-wi-fi-password-on-various-...
PC WorldFeb 11, 2013 - But Wi-Fi passwords, like every other kind, need to be changed every so often. Here's how to ... Android. You can't simply change the password here; you'll have to delete the network from your phone or tablet and recreate it.Missing: orca
How to Connect Your Android Tablet to a Wi-Fi Network ...
www.dummies.com/.../how-to-connect-your-android-tablet-to-a-wifi-net...
After you've activated the Android tablet's Wi-Fi radio, you can connect to an ... ... Be careful when connecting to a non-password-protected network. It's possible ...Missing: orca
How do i change my wifi password [Solved] - WiFi - Cell Phone ...
Dec 14, 2015 | RCA 8" Android Tablet w/Dual Tuner
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
I cant get my tablet to connect to wifi
Android tablets, unlike Android phones, don't require mobile phone service or a contract with a mobile phone company, and several models use Wi-Fi for network connectivity. The Android 3.0 operating system, known as Honeycomb, is designed specifically for tablets, and has the same features for Wi-Fi connections that are available with earlier versions of Android. Android tablets support wireless connections encrypted by both WEP and the more-secure WPA.
Tap the "Apps" menu on the tablet screen. Touch "Settings." Touch "Wireless and Networks" and select "Wi-Fi Settings." Tap the "Wi-Fi" box to turn on Wi-Fi. The Android tablet scans for available Wi-Fi networks and displays them on-screen under "Wi-Fi Networks." Tap an available Wi-Fi network. Touch "Connect" if it is unsecured, or enter the password or passcode for the encrypted connection.
Tap "Connect."
Jan 14, 2013 | Polaroid 7 in. Internet Tablet
Connecting a genbook to wifi
Turn on your computer and locate the Wi-Fi icon.
This is located in the system tray in the bottom-right corner of the screen.
The icon looks like a series of rectangles that increase in size from left to right.
Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks.
Choose a Wi-Fi network you want to connect to and select "Connect."
Enter the password into the password text box if a password is required. If a password is not required, you will automatically connect to the Wi-Fi network.
Click "OK."
Oct 11, 2012 | Computers & Internet
How do i connect wifi from my samsung mobile
Follow the steps :
Press the "Start" key on the front of the phone, located to the left of the "OK" button, and press down the circle around the "OK" button to scroll to "Settings." Press "OK" to select "Settings," and select "More."
Highlight "Connections" on the screen and press the "OK" button. Select "More" and highlight "Wi-Fi." Press the "OK" button to enter the Wi-Fi settings.
Press the "Menu" key, located on the right side of the "OK" button, and highlight and press "OK" over "Turn on Wi-Fi."
Select "Yes" to view the Network List, and press the "OK" button over the highlighted network you wish to connect to. Select "Connect" and the network type, and select "Next" to proceed.
5
Type in the network password, and press the "Next" key on your phone. Press "Finish" to complete the network setup. A Wi-Fi icon will appear at the top of your screen when you are connected to a wireless networ
Oct 26, 2010 | Computers & Internet
What is wi fi whats does it do
Wi-Fi stands for wireless fidelity. The term Wi-Fi, which is alternatively pushed by the Wi-Fi Alliance, a trade group that pioneered commercialization of the technology. Wi-Fi is mostly about connecting to the Internet without physically attaching your computer to anything. Mostly it's about using laptop computers.
A Wi-Fi enabled device such as a personal computer, video game console, mobile phone, MP3 player or personal digital assistant can connect to the Internet when within range of a wireless network connected to the Internet. The coverage of one or more (interconnected) access points — called a hotspot — can comprise an area as small as a few rooms or as large as many square miles. Coverage in the larger area may depend on a group of access points with overlapping coverage. Wi-Fi technology has been used in wireless mesh networks, for example, in London.
In addition to private use in homes and offices, Wi-Fi can provide public access at Wi-Fi hotspots provided either free-of-charge or to subscribers to various commercial services. Organizations and businesses - such as those running airports, hotels and restaurants - often provide free-use hotspots to attract or assist clients. Enthusiasts or authorities who wish to provide services or even to promote business in selected areas sometimes provide free Wi-Fi access.
Routers that incorporate a digital subscriber line modem or a cable modem and a Wi-Fi access point, often set up in homes and other premises, can provide Internet-access and internetworking to all devices connected (wirelessly or by cable) to them. One can also connect Wi-Fi devices in ad-hoc mode for client-to-client connections without a router. Wi-Fi also enables places that would traditionally not have network access to connect, for example bathrooms, kitchens and garden sheds.
Good luck and have a nice day.
rating the solution is highly appreciated.
Jul 29, 2010 | RIM BlackBerry Curve 8520 Smartphone
Do not know how to go online
(Im using Megaman Starforce 2 for demonstration)
First,get a game with the Wi-Fi logo(its a blue circle with Wi-Fi in white letters).Then you need a Wi-Fi connection,as thats what connects you to the internet.If you can get close enough to a signal,go into the game and look for WI-Fi settings or Wi-Fi configuration in the game menu.You will get a nintendo menu with Nintendo Wi-Fi Connection Setup.Press Nintendo Wi-Fi Connection Settings,press connection 1(or whatever number is avalible)and search for an access point.Press the access point that you want(or that is avalible)and then let it test the connection.Now enjoy the game on the internet!(remember to do this for any game you buy,and also if it is a temporary connection,remember to delete it once your done with it.)
Hope it helps,if not,ask me any other questions!
Nov 01, 2009 | Nintendo Video Game Consoles & Games
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
How do i connect to mcdonolds free wifi? what do i need?
To access the Wi-Fi services in a restaurant, you need a Wi-Fi enabled device, such as a laptop or PDA. If you are unsure whether your laptop or PDA is Wi-Fi enabled, click here to determine what hardware is required.
Our local service providers provide high-quality Wi-Fi service through several convenient connection options: on-line credit card payment, subscriptions, prepaid cards, or (sometimes) promotional coupons. If you have questions or need technical help, the Wi-Fi provider's customer support number should be handy in the restaurant.
Please note that currently there are no roaming capabilities between different countries, neither for customers nor McDonald's employees. You will have to connect separately with the respective Wi-Fi service provider.
Enjoy surfing and working in your local McDonald's!
Nov 05, 2008 | Computers & Internet
HELP
All you should have to do is open Wi-Fi in system preferences. From there, touch the little blue circle next to the Wi-Fi network you're signed. Then, just hit "Renew Lease" at the bottom of the screen.
If that doesn't do it, completely turn your modem, Wi-Fi router and iTouch off. After 5 full minutes, turn on the modem, another 2 minutes later, turn on the Wi-Fi router, yet another minute at least, turn on your iTouch.
If that still doesn't work or you have any questions, feel free to call me.
Dan Crowley, iKnowApple.com 919.280.3101
Nov 04, 2008 | Apple iPod touch
Samsung HT-Q100 System Logo
44 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
