Question about Cameras
Move photos from pc to ipad - Cameras
How do I transfer photos from ipad to Sandisk media player?
get a hold of a tech from apple, they should be able to guide you
Mar 03, 2015 | SanDisk Sansa e250 MP3 Player
Transfer photos from my PC to my ipad mini. I have tried iTunes but I don't understand it
Try downloading an app called Shareit.
When attached to the same WiFi, you can transfer Photos directly from iPad to iPad and even between Windows and Andriod devices. You start Shareit on both devices and send from one and receive on the other.
Feb 16, 2015 | Apple iPad Mini
How do I transfer photos from ipad to PC
Plug ipad into pc, open iTunes and transfer from there!
Nov 09, 2014 | Home
How to transfer pictures from apple ipad to toshiba laptop
you can transfer DATA from ipad to PC using itunes
Aug 05, 2014 | Toshiba Computers & Internet
Copy photos from PC to Ipad
Connect your iPad to your PC. Start iTunes. In the left column of iTunes on your PC you should see your iPad listsxed. Select your iPad. Look for photos in the bar at the top of the right column in iTunes on your PC.
For more detailed guide of transferring photos from PC to iPad, follow this tip "Copy files from Computer to iPad".
Jun 01, 2012 | Apple iPad2 WiFi 64GB
How do I delete a photo on an IPad?
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to remove from the iPad under the Sync Photos from heading.
5.If you want to remove all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
More info: How to delete a photo on an iPad
Aug 28, 2011 | Apple iPad 32 GB WiFi Tablet PC
How do I download photos from my laptop (Toshiba Satellite) to my ipad?
To transfer photos from your Toshiba laptop to your iPad:
Step 1: Connect your iPad to your Toshiba laptop using the USB data cable that came with your iPad.
Download Install and run iTunes and select your iPad device from left panel under "Devices" section.
Step 2: Click on Photos tab, Check the "Sync Photos from" checkbox and select "Choose Folder..." option from drop-down menu. Locate the folder with the photos you want to transfer on your computer and hit "Select Folder" button.
Step 3: When folder listed in iTunes, select all pictures that you want to copy to your iPad and hit Sync/Apply button from bottom right corner.
Jul 12, 2011 | Apple iPad 32 GB WiFi Tablet PC
I want to transfer my pics from my computer to my I Pad but doing it by Email is slow, is there a better way?
Follow the steps to transfer pics from your computer to your iPad:
Step 1: Connect your iPad to your computer using the USB data cable that came with your iPad.
Feb 17, 2011 | Apple iPad 64 GB 3G Tablet PC
The PC on which I had itunes that synced with my ipad is no longer available. I want to transfer the music on my ipad to a new PC (with itunes). How do I do this transfer?
You can use iPad to PC Transfer, which can help you transfer from iPad to PC. iPad to PC Transfer is a professional sofeware, which can help you transfer Music, Movie, Photo, ePub, PDF, Audiobook, Podcast and TV Show from iPad to PC or iTunes library.
Dec 20, 2010 | Apple iPad 32 GB WiFi Tablet PC
Cameras Logo
18 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
