Question about RCA 14F512T 14" TV
No Pic...power light only, on plug in
Found burnt resistor R414...Do you have schematic for value? Thanks AL
  • AL PUG Sep 28, 2007
    Thanks Guru!! I will let you know if it does the trick!...AL
  • AL PUG Sep 30, 2007
    Well Guru...She still dont power up. There is a small square black box RT801 that heats up ( probably because no current is going beyond it) So the burnt resistor is a clue...what do you suggest to check next?...Thanks AL
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
R414 is a 13K ohm 1/6 watt resistor.
Posted on Sep 28, 2007
  • David Makowski
    David Makowski Oct 01, 2007
    I only have a parts list - these models are under RCA's "exchange only" service plan and there is no service information available.
    (Walmart sells them new for $69)
SOURCE:
LG crt tv 21fs4rge-TS resistor R407 burnt i don't know the value
A burned out resistor means too much power has flowed and burned it out.
you need a schematic to find the resistor value but also what other parts have blown as I can guarantee just replacing the resistor would just mean another burned out resistor.
Jun 16, 2018 | LG Televison & Video
Where can I download the schematic diagram of zed 22fx?
all resistors are banded with different colors and each band has a specific value
band colors range from black , purple, orange yellow dark green blue red grey and white and color diagrams and values can be found on the net or from shops like Jaycar
however if you want a schematic diagram if you go google and type in schematic diagram for zed 22fx you may be lucky enough to find a pdf version down load
if such a diagram is unavailable unsolder yours and take it to the shop and have it identified and they will have spares for sale
May 04, 2016 | Music
How do i know the value of r414 and cr405s?because it was burnt.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams to many popular brand TVs are given. Hope it will help you to find out the resistance value.
Mar 21, 2015 | Televison & Video
Samsung home-theater model no# HT-E330K, power supply resistor RA805 completely burnt can't see the value of the resistor. Pls help with the value of the resistor
This may sound like a lazy answer but without a schematic, its going to be tough. Perhaps you know someone...or maybe there is someone here who has the same unit who wouldn't mind opening it up to get the value. Good luck.
Oct 08, 2013 | Audio Players & Recorders
Resistor values
Request a schematic diagram and parts list from Kicker.
Jul 15, 2017 | Kicker ZX650.4 Car Audio Amplifier
Power supply burnt
R106 is a .5 ohm. It is green,black,gold, and silver. I believe it is a 1/2 watt resister
R103A is a 27 ohm and R108A is a 470 ohm resister.I have no schematic.
Sep 22, 2008 | RCA DRC8335
DBX 100 Boombox
I don't recommend this, but the resistor you speak of is probably a small fuse. Try jumping out the fuse, then turn on unit for brief moment. If it powers up, fine. Replace jumper wire with 1 amp fuse. If not, take to prof. tech.
Apr 12, 2008 | Audio Players & Recorders
Need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Mar 24, 2008 | Hitachi 57SWX20B 57" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
RCA 14F512T 14" TV Logo
164 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
