Question about Tablets & eReaders
My Hannspad 10.1 Tablet PC SN1AT71BUE is not starting up with power button, anyone help me with this ? I know that sometimes it's just a few buttons and its fixed. Anyone have any ideas ? Thank you so much for your help.
dugiehowsa
  • 114 Answers
SOURCE: Do I need a battery to run the PC Tablet?
THe manual for your specific model can be found here: http://support.fujitsu-siemens.com/Manuals/ShowDescription_KMT.asp?DokuID=202607 Documents for othe models and languages can be found here: http://support.fujitsu-siemens.com/com/support/manuals.html
Posted on Sep 25, 2006
nliwilson
  • 114 Answers
SOURCE: Mobits A221 tablet pc reset
You can forcibly power off the unit in exactly the same way you can any PC, hold down the power (on/off) button for 6 seconds.
Technically it's actually 4 seconds but 6 seconds gives you a margin of error. Unfortunately Microsoft make poor quality products and Windows XP Tablet Edition is no exception, Keep a a note of this procedure as this won't be the last time you need it.
Posted on Dec 04, 2007
SOURCE: dismantelling Averatec 3500 series tablet PC
I have this same laptop. It is pretty simple to tear apart. Is there any specific areas you wish to access or did you want to just take it completely apart? If you are going ofr the keyboard ribbon or the touchpad ribbon, just undo the two screws out that are located behind the pivot point of the screen, then open the laptop and remove the small plate. This reveals access to two more screws (2 silver, 2 black). Remove the silver ones not the black ones. The black screws remove the lower shell assembly. Once the silver screws are removed the accessory bezel can be removed. ( the one with the power button and lights)
There are yet two more screws that lock down the keyboard. Remove them and pivot the keyboard toward the touchpad. You can now safely remove the keyboard.
Posted on Mar 02, 2009
SOURCE: Clean dust from tablet pc screen
You have to remove the screw covers (the black squares around the screen), remove the screws and gentley pry the cover open with yor finger nails or a flat head screw driver, but be careful not to dent the sides with the screw driver. You can then take a can of air and blow the dust out. I would not touch the sensetive screen under neath. You could take a anti static, micro fiber cloth to wipe off the tough stuff.
Posted on Mar 25, 2009
jg1426
  • 31 Answers
SOURCE: How to remove the onscreen keyboard on the gatewat tablet pc
Here is the URL with a possible solution to disable the onscreen keyboard on a tablet PC: http://www.tech-recipes.com/rx/1941/tablet_pc_how_to_remove_on_screen_keyboard/. Here are the steps from the site, just in case the URL dosent work:
TO DISABLE ON SCREEN KEYBOARD
1. Click the Start button. 2. Select Run.
3. Type in: regsvr32 /u "C:\Program Files\Common Files\Microsoft Shared\Ink\loginkey.dll"
4. Click the OK button.
To restore the On-screen Keyboard:
2. Select Run.
3. Type in: regsvr32 "C:\Program Files\Common Files\Microsoft Shared\Ink\loginkey.dll"
Let me know if this helps you out....
Serge
Posted on Mar 30, 2009
My tablet will not turn on after charging it all night. Can I change the battery?
press and hold the power button 10 sec ?
Press and hold both power and volume down buttons for 10 seconds, then release vol. down button while holding down power button for another 10 seconds, before releasing.
plug to pc and wait to be recognized?
take out the battery so that samsung fully discharge so this should help reset replug the battery.
Jan 04, 2015 | Supersonic 9.7" Android Tablet SC-97JB
Hannspree tablet 10 1manual
See a part of the specs, down here.
Be aware the 32 Gbyte can't be used as internal memory. It only can be used like an external hard disk. You can exchange the SDHC card and save data you don't need to access while running the tablet.
So when the tablet says memory is full, you should transfer data like images and videos to the external card and then delete the data from the internal memory.
Jul 25, 2014 | Hannspree HannsPad SN10T1
Tablet to tv using hdmi only works for 10 to 30 seconds then tv says no support
have you tried chromecast? Its awesome and uses wifi to hdmi technology.
Jan 30, 2014 | Hannspree HannsPad SN10T1
Manual for sn14t7 13.3" hannspad tablet
Here is the PDF file for the SN14T7 13.3".
http://www.hannspree.eu/uploads/Downloads/TabletPC/UM/SN14T71/SN14T71_Users_Manual_EN.pdf
Dec 27, 2013 | Hannspree HANNSpad Tablet User Manual
I have bought HANNSpad SN1AT7 Tablet ,it is full charged ,I've tried switching it on but alli get is the screen saver nothing else
Remove the battery cover and remove battery for about 30 seconds. Then replace battery and power up your tablet and see if that does not reset it.
Dec 09, 2013 | Hannspree HANNS pad SN10T1
Hannspree Hannspad user manual
My 10.1 hannspreed tablet will not download free games after I reset it to factory,what did I miss ?
Feb 14, 2013 | Hannspree HANNSpad Tablet User Manual
Bought my tablet as a window display item. archos 101 How to end demo mode ? Thanks
Power off by holding the power button for 10 seconds.
Press "Volume +" button and power it on (press power button to start while holding "volume +" until the tablet displays recovery mode. Select the "Format System" option.
Jul 06, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Tablets & eReaders Logo
101 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
