Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Part number for springs on the door of kud101flss5
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 | Dishwashers
The cradle actuator on my kenmore ice dispenser will not spring back , I do not know where the spring attaches ,
Look for your model number around the fresh food section door. It will look like this=> 321.1234567
Without your model number it will be hard to help explain or provide an example. Sea Breeze
Dec 15, 2013 | Kenmore Refrigerators
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Oven door spring model av 669 26a
MFG Part Number:WB9K4 if spring is red -MFG Number WB9K5 if spring is black with a spot of blue paint. To access the spring remove the storage drawer. One end attaches to the hinge the other to a slotted hook. Check the opp. side spring to see how it is hooked up.
Feb 05, 2013 | Tappan TGF364AS Gas Kitchen Range
The door spring is broken and the door falls open
there is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
Feb 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I opened teh door and thought i felt something hit
Murray, It sounds like one of the door springs has broken and that is why the door seems heavier and opens with much more force.
You'll want to at least make a temporary repair and order a new replacment spring to get your dishwasher working like it should and so it's safer too.
You can check to see which side of the dishwasher the spring broke, by locking the door shut (with the cycle set to "off"). Now remove the lower access panel, beneath the main dishwasher door. There are a couple of screws near the top corner edges of the panel, just under the main door and a couple more on the toe kick near the very bottom.
Once you've got the lower access panel off, you'll be able to see the two door springs, (there is one on each side). Of course, the broken one might have fallen off the spring notches, so look around and you should see it.
With the door still closed and locked, you can remove the broken spring and see if it's just the hook end that broke. If that's the case, you can reform the end hook using a couple pairs of pliers and reinstall the spring on the door and frame mounting points. You'll have to use pliers to stretch the spring slightly to get it on the other mounting point, once you've got one end on a mounting point. If the spring broke off more than 3 coils, you'll need to replace it with a new one.
You can find a replacement by using searspartsdirect.com and putting in your model number to locate a line drawing and parts listing for your particular model. You can also order a new one from them, or use the part number to get one locally, if you wish.
Once you've got the spring back on the door and cabinet mount points, you can unlock the door and gently lower the door to see if everything is working properly. Once you've opened and closed the door several times, you can reinstall the lower access panel and you're back in business.
I hope you find this Very Helpful and best regards!
Oct 24, 2009 | KitchenAid Dishwashers
Door is broken
Hello Hickin! It would appear that one, or both of the door springs which act as a counter-balance for the weight of the door, have broke.
To confirm this and get at the spring(s), close and lock the wash compartment door and use a screwdriver (might be a 1/4" or 5/16" nut driver instead) to remove the lower panel.
Once you have the lower panel off, you should be able to see the door springs on each side. You'll probably also see part of the broken spring lying in there too. If the door spring broke near the end by the hook, it is possible to TEMPORARYILY bend the spring with a set of channel locks and pliers to form a new hook end, that you can attach to the door clip. If the spring is broke near the middle, you'll need to get a new one.
Regardless, you'll need to locate the model number for your dishwasher and obtain a replacement spring ASAP, as the temporary repair will only work for a short while before the spring breaks again.
You might want to try Fagor at their site to see what the part number for the replacement spring is. http://www.fagoramerica.com/
The other option with your model number is to try the Sears part web site, which shows a line drawing and parts list for most applianances.
http://www.searspartsdirect.com/partsdirect/index.action
This repair is relatively easy for anyone to undertake and you can save yourself the cost for a service tech's labor charges, plus the trip/house charge they normally tack on.
Oct 12, 2009 | Fagor Dishwashers
Broken door spring?
Either a spring or a door cable. On newer Kitchenaids and Whirlpools, it is usually a "cable" made of rope and plastic that breaks, not the spring itself. Get me the complete model number and I will look it up for you...
Dec 14, 2008 | Dishwashers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
