Question about Watches
Danbury book clock, how do you take clock out to put in battery?
  • 4 Answers
The clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Posted on Dec 08, 2015
How to put hands back on battery operated wall clock
put the smallest one on first and the longest one second
Oct 18, 2015 | Watches
Danbury clock 'things remembered'. How do I access the battery? I cannot figure out how to find the battery. The battery is dead after two years and I need to replace it. It is not obvious how to...
The things remembered clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Jan 31, 2014 | Watches
How to you change the battery in a danbury book clock
The clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes free. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Jul 30, 2013 | Watches
How do I set a Danbury pocket watch with date display
If it is this pocket watch, then the crown (the bit you turn to wind the watch) has 3 positions. Position 1 is when the crown is pushed in all the way. Position 3 is when the crown is pulled out as far as it will go. In between position 1 and position 3 is a place where the crown will stop, this is position 2.
To set the day of the week, pull the crown out to position 3 to set the time. When you set the time, the bottom dial with also turn to set the hour on the 24 hour clock, if you turn the crown enough to cycle through a whole day the day of the week dial will also turn. Keep turning the crown until the time is set on the proper day of the week.
To set the date, pull the crown out to position 2, and turn it clockwise until the hand on the date dial points to the correct date.
Hope this helps!
Sep 01, 2012 | Watches
How do I change the battery on fossil motorcycle clock?
You will need a very small (watch or glasses) Philips head screwdriver, and a SR626SW (or know as a 377) watch battery.
Remove screw 1 to remove the motorcycle back cover.
Remove the other 2 screws to take off the clock backing.
Remove the white plastic ring by pulling directly up.
Remove the battery.
Put the new battery in.
Press the white plastic ring back on.
Reassemble the clock backing with the two screws.
Reassemble the back of the motorcycle with screw 1.
May 24, 2012 | Watches
I have a Relic airplane clock and I do not know how to replace the battery, the number is RML0000040. On the bottom of the plane is Limited Edition and China Case
It's not easy. You're probably better off brining it to the jeweler unless you already have the tools. You'll need a precision screwdriver set. Under the clock there's a tiny screw. Carefully remove that to pop the clock off the front of the plane -- don't strip it. Then get a standard flathead screwdriver to remove the cover behind the clock. Just turn it so that the tabs on the cover appear in the little openings around the edge. It should then fall out. If not, use a tiny screwdriver to remove it.
Under there is the clock. Remove the plastic spacer. You'll see the tiny little battery, which is held in by a tiny metal arm. Move the arm and the spring behind the battery will pop it up a little. Use a tiny screwdriver to carefully remove the battery. The battery is SR626SW.
Have fun putting it back together! Whoever designed this thing is on my s-list.
Apr 16, 2010 | Watches
I put a fresh battery in my new wall clock and it wont work
had the same problem myself. make sure that the hands of the clock are not bent inwards as to touch each other and get stuck.
my ones wre bent , a simple straighten solved my problem and the clock then worked fine. hope this helps
Apr 05, 2009 | Watches
Clock cleaning
This is not as easy as you might think. We learn decades to repair (cleaning included) watches and clocks. Any tip would be with no use, as every clock needs individual and specific attention.
The only tip is: visit an eBay and buy the clock repairers book. I've seen some books there.
All this is under the ''Jewellery and Watches'' section.
Mar 27, 2009 | Watches
Watches Logo
51 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
