Question about Garrity G Tech Flashlight Uses Two D Batteries Included Yellow
Yellow botten turn hard and well not push for light to come on & off
Yellow machine power out won't restart
You will have to get a disk recovery specialist to retrieve your data. The internal YellowBox system is Linux. The specialist will remove the disks and attach them to translation and recovery technology. It will cost money.
Dec 19, 2013 | Anthology Solutions Yellow Machine P400T...
My power light turns yellow instead of red i have to hold thepower botten to make it red
With the Wii system, when you hit the power button, it goes into Standby mode. That is the yellow light. In standby mode, the system draws a little bit of power, and it will go into a ready to play state faster than when Off. Holding the power button FULLY powers off the Wii system, and that will give you the red light. Hope this helps!
Feb 27, 2011 | Video Game Consoles & Games
Push power botten starts comeing on then cuts off
Try to unplug the computer from the power outlet for 5 minutes and turn it on.. if it still the same have the battery of the bios be removed to restore the default settings then try to restart the computer. If this would not work call the computer's manufacturer to have it warranted.
Sep 09, 2010 | Gateway GT5220 PC Desktop
Can noy find the reset botten on my compaq v6000
Some computer don't have a reset botten, but you can turn off the machine by puching the star botten for 5 second.
Jan 18, 2010 | HP Compaq Presario V6000T Notebook PC
I have a acer aspire 5050 lab top which started giving problems these days.The problem is that the hard disk dose not get started when the power botten is pressed on. It's not the problem with the power...
sounds like there is a problem with the hard drive.
your say the power boots on but the hard drive id not starting when power is pushed. try going into bios and load default settings.
if this does not fix the problem you may be in need of a hard drive. do you hear any rattling when the drive starts up?
Nov 13, 2009 | Computers & Internet
I HAVE AN ASPIRE 3680. IT WONT START WINDOWS
first connect it to the power then press the power botten continusly till it is shutdown. After that press the power botten again to start it then press F8 key. go to boot with last known good configaretion. if this doesn't work then you definite ly requir the os cd to repair the os.
Sep 21, 2009 | Acer Aspire 3680 Laptop
My play botten on my mp3 is half way in it.
HOLD play for a few secs. if it doesn't work, then its a hardware/software (not firmware) problem.
Feb 11, 2009 | Nextar MA933A MP3 Player
I have a bluesky tv with the parental lock switched on i have no remote control to turn it off anyone got any ideas
Buy a cheap universal remote and set it to your tv codes...go to menu and set-up Try pushing reset botten on back of tv!
Dec 06, 2008 | Televison & Video
Garrity G Tech Flashlight Uses Two D Batteries Included Yellow Logo
54 people viewed this question
Top Garrity Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Garrity Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
