Question about HP Officejet Pro 8600 e-All-in-One - multifunction fax / copier / printer / scanner color
The scanner is currently in use. Please wait until your previous task is completed and then try scanning again
2 Suggested Answers
christian_HP
  • 89 Answers
SOURCE: I get the following message
Are you getting the message from front panel of the printer or on the PC?
If from printer
check if printer can print test page by going to set up then go to printer status report
check if printer can make a copy as standalone
if not
power cycle the printer
if still unresolved
restore the printer to factory defaults by checking to set up>tools>restore factory defaults
If from the PC
restart pc
click on the black printer icon on your desktop
click on activate scan to pc
if issue persist go to the link below
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-90930-1&lc=en&dlc=en&cc=us&os=4063&product=4083977&sw_lang=
download the scan diagnostic utility
it can fix scan issues when it comes to software
I Can't Scan in Windows Using HP Software
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02661093&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=4083977
Hope I help you a bit.
Your's Truly,
Christian from HP
Posted on Mar 27, 2011
I saw the error "an error occurred during preview. if the scanner is being used. please wait for it to complete the task.and then click preview" when iam attempting to preview the scanned pictur how c
If you continue to get this kind of error after restarting the computer, you may need to update the scanner's device drivers or reinstall the included software. You should also make sure only one program or application is attempting to use the scanner by closing all but the one program you are trying use with the scanner. One last note - always either let the program you are scanning to operate the scanner or let the scanner invoke its default application by pressing the scan, fax or copy buttons on the scanner. Do not for instance try and scan an image into a running program that initiates the scanning process itself while also invoking a scan from the scanner's control panel. The two operations will conflict.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 19, 2014 | Office Equipment & Supplies
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
I have a radio shack pro96 i can not reboot it to restall the v scannfolder what can i do i have tryed everything to wipe it clean
Sounds like the motherboard is corrupted. Please try these steps again. Thanks!! Happy Scanning!!
I need to ask you this. Normally one bank can't be closed.
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Apr 11, 2011 | Radio Shack Pro-2096 Base Scanner
I get the following message - "The scanner is currently in use. Please wait until your previous task is complete and then try scanning again." I have a HP Officejet 6500A. What causes this and...
If from printer
if not
if still unresolved
If from the PC
restart pc
Your's Truly,
Christian from HP
Mar 27, 2011 | HP Office Equipment & Supplies
I try to scan to my pc as a pdf for email, and then it wont let me do anything else and says the scanner is working on another task. How can I cancel the previous scan?
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer at the time of your scan select end now to stop the previous scan you might have a virus also select users you will see who is using your computer
dont forget to vote
hope this helps
Feb 07, 2011 | Computers & Internet
Today I scanned a Business card then quit the scanner then again i opened the scanner to scan but it shows the scan sizard quit unexpectedly.what to do now?Please help
check if you find the digital imaging monitor in the task bar of the computer..
try to scan from the solution centre .. if it is not scanning.. you may have to try L2 uninstall.
Aug 14, 2010 | Office Equipment & Supplies
I have A radio shack PRO-2096 and have not been able to use it in over A year. it reads all channels locked out. I can't unlock it.can someone please help me?
Please try this!!
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Jun 23, 2010 | Radio Shack Pro-2096 Base Scanner
IT WON'T BUDGE. IT READS ALL CHANNELS LOCKED OUT. PLEASE HELP
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Hope this works happy scanning!!
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
HP Officejet Pro 8600 e-All-in-One - multifunction  fax / copier / printer / scanner   color Logo
988 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
