Question about Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY DOOR LOCK
A how to program my garrison keyless deadbolt model number 046-2667-4-2668-2 video
Where do i find the english instructions for installing Garrison keyless entry deadbolt lock? 046-2667-4. Got only french in box
Is this model sold in the USA or Canada? If not then you may have a problem getting the booklet in English. You could post the instructions and then use google to translate them.
Aug 12, 2016 | Deadbolt Locks & Locksmithing
Garrison
The manufacturer has a video for installing the electronic deadbolt, it might be helpful.
https://www.youtube.com/watch?v=UZ0nsArpesc
English vision
https://www.youtube.com/watch?v=SqAP2Jgd9n8
French vision
Should you still experience difficulty, please return to your store.
by
CanadianTireTeam
- CanadianTireAnswers
1 month, 2 weeks ago
May 18, 2014 | Locks & Locksmithing
Unlocking the door
Same issue. But I have Garrison instead.
Dec 29, 2013 | Deadbolt Weiser Powerbolt 1000 Keyless...
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
We have a garrison keyless entry deadbolt lock with remote entry. when we press the unlock on remote it locks and when we press the loke button it unlocks. If we press the onlock button on keypad it u
If you remove the inside housing from the door, and look inside on the left hand side of the circuit board, you will find a slot marked "L R".
Slide the switch to the opposite of what it is set for. This will solve the problem.
Jan 14, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
When I install new batteries it won't stop 'squealing'...what could be the problem? Ugh - I can't even use it like that!! thanks!
It was a Garrison - I've since learned that the problem was it was screwed a little too tight and was pushing against the circuit board. I took the back off (where the batteries are) and loosened the screws a little and the squealing stopped!
(Posted to clear the "unanswered questions" and share with the community)
Nov 25, 2011 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY DOOR LOCK Logo
1,047 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
David Belitz
David Belitz
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
