Question about Air Conditioning and Heat for Acura Rdx
Condensation dash fan orifice
Water under car when parked
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 26 Answers
Not to worry about this issue. This is normal with every A/C system in any vehicle
Posted on Jul 28, 2014
What do the fuse under the hood 2012 jetta do?
don't know what fuse you are referring to. does your condenser fan operate when you have a/c on and vehile idling in park? sound like you may have bad condenser fan if you a/c starts to work when driving at higher speeds because refrigerant is being condensed by ram air flowing through condenser.
Aug 28, 2014 | Cars & Trucks
2000 acura tl coolant fan after fluid change
New thermostat, installed, saw, new coolant made a little mess filling reservoir, (normal) checked fan fuse for some reason, and condenser fan fuse (xxx ?:), and temp guage, is slightly lower on gauge (than normal?) (disconnected xxxx? quit? a bit? to get to thermosta?.t no dash warning lights have a feeling I popped a relay.
Answer:
ok, you did a coolant service with STAT,
and it failed.
tell us what works right and wrong, symptoms only.
over heating? parked, (fan never comes on)? as it hits 225F?
under heating? ( fan stuck on , up North can cause huge cold engine)
dash gauge stuck low. (thermostat wrong heat range 180f is best. see FSM for spec. on this temp. spec..
Dash guage varies.? oddly (air in system)?
Dash gauge too high.? (Stat put in upside-down or bleed hole (jiggle) not UP side. higher side of mount , trapping air.)
Does something wrong happen only driving?
leaks?
does cap on rad hold 12-14psi pressure, hot.?
if car has fan belts, are they tight? (for sure water pump does)
Nov 19, 2013 | 1994 Honda Civic
Carpet on both sides under dash is getting wet from air condition condensation
there is a condensate drain line that must be clogged or , most likely , the hose pulled off the drain tank . look under pass. side dash for a disconnected rubber hose.
Aug 01, 2012 | 2004 Ford Explorer
A/C part condensation water in center under dash is leaking on floor. Is there a way to put a pan around it to catch the water and then drill hole in it and run it out side.
YOUR EVAPORATOR DRAIN TUBE HOLE STOPPED UP.SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS.MAKE SURE VECHICLE PARKED ON SOLID LEVEL GROUND.GO UNDERNEATHER VECHICLE ON PASSENGER SIDE WHERE HEATER CORE HOSES GOES INTO FIREWALL LOOK UNDER THAT AREA FOR THE EVAPORATOR DRAIN TUBE HOLE USE SHOP VAC TRY VACUUM DEBRIS AND TRASH BUILD UP OUT OF DRAIN TUBE HOLE SEE WHAT HAPPENS.
Sep 30, 2011 | 1994 Pontiac Grand Prix
I can hear water when I make a right turn butit comes out on back floor
Do you see water dripping under the car when your A/C has been running? I would suspect a clogged condensate drain. The drain lines are usually capped with a rubber device that, lacking a better description, have "lips" that close to keep dirt and bugs out but open to release built up water in the condensate pan. Sometimes these rubber device's "lips" stick together (particularly as they get older) and will not let the water drain.
Look under your dash, probably on the passenger side, and see if you can find the drain line from the evaporator coil. Trace where the drain goes through your floor board. Look under the car for the drain outlet and the rubber cap device. Make sure that it is not clogged.
Jun 11, 2011 | 2000 Buick Park Avenue
Water dripping under dash drivers side. Is that the heater core?
Taste it,if it is sweet it is,but if it just taste like water,it is the condensation from ac,the drain needs to be unstopped.
Jul 05, 2010 | 2000 Dodge Caravan
Why when fully charged yet it dose not cool
Lot of reasons for this,The orifice tube can be stopped up,or the condenser is,or the fan is not cooling the condenser,or the compressor is bad,,and,if the temp door in the dash is not opening all the way,this would cause this situation.
May 27, 2010 | 2004 GMC Envoy
Overheating car
This is a fairly common problem. The engine is overheating because the secondary fan is most likely not coming on. Here is a good way to check. With the car in park and the engine idling turn on the air. When the air is on the secondary fan should start. If the fan doesn't start then you have found the problem. The fan relay is usually the problem. You can locate this relay by looking in your owners manual. also check the fuse and the plug at the fan for a loose connection. hope this helps. Good luck.
May 11, 2009 | 1996 Oldsmobile Aurora
Leaking water feom car
This is almost certainly water that has condensed from the atmosphere and is dripping from the condenser of your A/C unit. This is totally normal and nothing to be concerned about.
Jun 04, 2008 | 2006 Ford Focus
Air Conditioning and Heat for Acura Rdx Logo
75 people viewed this question
Top Acura Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
 TE5LA
TE5LA
Are you an Acura Vehicle Part and Accessory Expert? Answer questions, earn points and help others
