Question about Samsung TXE2546 25" TV
Vertical size About a six inch black space at top of screen
  • jarhead217 Sep 27, 2007
    THANK YOU.....MODERN
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Your problem in vertical outout section only. check feed back line. most probably electrolytic capacitor failure.
Posted on Sep 27, 2007
SOURCE:
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
White lines at the top 3-4 inches of the screen.
well its all new now could be bad caps or vertical i.c. okay if you have a esr meter check around the i.c. for a leakey cap good luck
May 13, 2009 | Insignia NS- 27" TV27 TV
There are 2 inches of black space on both sides of my screen.
There should be a way to go into the screen settings on the set (either from the remote or on the bottom of the screen). From that menu you can adjust the size of the screen, stretch it, align it, etc.
May 04, 2009 | Emprex LM2201 22" LCD Monitor
LCD TV picture has vertical lines through picture equal spacing
Call 323-767-6030 and I will go through with you.
Dec 09, 2008 | Televison & Video
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
[email protected]
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Vertical section problem
I have found an fix for this a capacitor 2494 needs to replaced.
Aug 21, 2008 | Philips 27MT3305 27" TV
Wide black area top of the screen.
More than likely it's not the crt. If the picture has "foldover" at the top of where the picture is currently, then more than likely there are bad caps. in the vertical scan circuit. If not, the vertical sizing probably just needs to be adjusted. You will have to get in to the service menu to do that.
May 26, 2008 | Philips Magnavox 27MT5405 TV
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 18, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Full screen on monitor
you can use the menu and adjust the vertical size.or if did already but it doesn't work,try to open your monitor and look for a trimmer in the vertical section,then try to rotate by these you can adjust now the vertical size
Oct 18, 2007 | HP Compaq FS7600 17" CRT Monitor
Televison & Video Logo
80 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
