Question about ASUS Recertified - X55A-RBK4 Intel Pentium B970 2.3GHz 15.6" Windows 7
Hard disc problem - ASUS Recertified - X55A-RBK4 Intel Pentium B970 2.3GHz 15.6" Windows 7
    New Friend:
    Problem Solver:
  • 12 Answers
Can u elaborate what is the problem with hard disk? Is it not booting up? or Windows 7 is causing some problem? what exactly is the issue?
Posted on Oct 20, 2013
Brake discs. What mileage can be expected from brake discs on 2015 model E220 estate?
normal brake applications ( gentle applications to slow down rather than hard stops ) up to 100,000 klms-60,000miles on mid hardness brake pads
there are 3 levels of hardness on disc pads and each affects the life of the discs
Apr 13, 2017 | Cars & Trucks
Tip
Xbox help for "Can read CD but NOT DVD."
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
on Feb 15, 2010 | Video Game Consoles & Games
Tip
How to play a scratched disc on xbox 360 or some other consoles
Note: I have only experienced using this trick on the XBox 360 Console.
One common problem that video game players have all the time are scratched discs. A helpful way around buying a brand new game or a disc scratch remover, is to first:
a.) Borrow the same version of the game from a friend
OR
b.) Rent the same version of the game from a store
Now, take the unscratched disc, and install it to your hard drive.
And lastly, now you can put in the scratched disc and go to "Game Library", choose the game, and select "Play from Hard drive."
The reason this trick works, is because when you play your disc from the hard drive, it uses minimal memory from the disc itself.
NOTE: Installing a disc to your hard drive does NOT replace having to put in the game to play it.
You still need a copy of the game in order to run it from your hard drive. I believe this is some security feature so people don't go around copying the games and not buying them.
Also, I would NOT install the scratched disc to your hard drive, for this will not help your problem at all.
on Jan 23, 2010 | Video Game Consoles & Games
HOW TO TRANSFER FILES , SYSTEM FROM ONE HARD DISC TO ANOTHER
You can get a Recovery CD for your model laptop from ASUS WEB site and the laptop's device drivers.
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : -http://support.asus.com/download/download.aspx?SLanguage=en-us
Jul 18, 2012 | ASUS Computers & Internet
When putting in Forza Motorsport 3 the console makes a lound noise, like the fan is on overtime when reading disc a lot louder than other games. Tried other games after and just low hum. Is it the...
Likely that for some reason the Xbox is having a hard time reading the disc and it is spinning the drive trying to search for files on the disk. If you aren't having the same issue with other games then recommend to resolve this issue then simply install the game onto your hard drive and the game will then only need to be accessed for verification only and the game will be played off your hard drive and not your disk drive. Here are the instructions for insalling a game to your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Play a game from your hard drive
  2. Go to My Xbox, and select the name of the game you want to play.
Note The game disc must be in the disc drive, even though you have installed the game on your hard drive. The console will automatically play the game from your hard drive, but the disc has to be present.
Jul 18, 2011 | Microsoft Xbox 360 Console
Playstation 3 message "hard disc file system is corrupted..."
Your hard drive may have gone bad. Maybe try using a different hard drive. Once you put it in, the system data should install itself.
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
My 360 only plays cds or dvd s wont play games please advise
Feb 15, 2010 | Microsoft Xbox 360 Console
Fifa 09 football problem. telling me to clean disc as it is unreadable i am cleaning the disc and restarting the console but it keeps telling me to clean the disc.
OR
Jan 23, 2010 | EA Sports Video Game Consoles & Games
I cannot load windows xp pro
Go to BIOS and disable "NATIVE SATA SUPPORT"
Mar 20, 2009 | HP Computers & Internet
Hard Drive Problem
This has happened to me once. I unplugged it overnight and plugged is back in and everything (Except for the for the DVD that was being written when it malfunctioned) Worked fine. I suspect that a Capacitor is going bad but it’s still working (for 4 months) and I will put off any real trouble shooting until it fails hard.
Apr 25, 2008 | Panasonic DMR-E85H DVD Recorder
ASUS Recertified - X55A-RBK4 Intel Pentium B970 2.3GHz 15.6" Windows 7 Logo
61 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
