Question about KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher
4 hour delay light on Kitchenaid dishwasher Kuds30ixss does not turn off. How do I reset the dishwasher?
5 Suggested Answers
SOURCE: Clean Light Flashes
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Mar 24, 2008
SOURCE: dishwashwer won't start and can't reset to restart
Check the float. (dome shaped thing inside the washer) Mine was stuck but as soon as I lifted up on it and then reseated it I was able to return to normal. Almost too easy. Saved $!
Posted on Apr 23, 2009
praky16
  • 744 Answers
SOURCE: Kitchenaid custom 21 dishwasher will not turn on
Hi, this is a control fault that is localized in the logic sector of the control board. the logic chip which holds all wash programing is damaged. you will need to replace the control asap if possible...
thank u
rate me!!
Posted on Jul 27, 2009
erpaalai
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
Run a service test for kitchenaid dishwasher
Did you check behind the toe-kick panel for the tech data sheet? Assuming that you have checked and that it is missing, there here is the "secret keystrokes" that will make most Whirlpool/ KitchenAid/Kenmore/Maytag diswashers enter the diagnostic cycle:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Oct 18, 2014 | KitchenAid KUDS30IXSS Builtin Dishwasher
How do I get the delay wash light to stop flashing on my dishwasher
Unplug the washer from the wall for 1 min. then replug & give it a try. That should reset everything.
Sep 15, 2014 | KitchenAid Dishwashers
Dishwasher will not turn on and control light blinking
The command and control center may be damaged from a power surge or misuse. You need a new Powerboard.
May 09, 2014 | KitchenAid KUDS30IXSS Builtin Dishwasher
I have a Kitchenaid kuds25shwh1 which doesn't start because the childlock was on. I followed all the suggestions offered and lastly turning the power off to reset. After turning the power back on a...
Getting it out of child lock can be difficult but make sure you watch the light on the front panel it will go right back to lock if your not careful.I had to try several times at first I thought it would need a doctor.. but with patience it should work and unlock with the 4 second hold.. power down does not reset unless you wait 30 minutes or longer.. hope this helps
Oct 08, 2013 | KitchenAid 24 in. KUDI01FL - Multiple...
Needto reset system
turn off the circuit breaker connected to the dishwasher then on again
Feb 05, 2013 | KitchenAid KUDS30IXSS Builtin Dishwasher
Dishwasher leaves water on dishes and in dishwasher after the heat dry cycle is finished. What should I do?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 26, 2011 | KitchenAid KUDS30IXSS Builtin Dishwasher
Electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Aug 31, 2009 | Electrolux EDW5505ESS Built-in Dishwasher
Dishwashwer won't start and can't reset to restart
Apr 15, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher Logo
270 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
