Question about Panasonic Vintage Technics Receiver Model Sa 8000 X
I have a technics sa8000 2/4 channel but no sound lights up but that it had for but but just died any ideas
Technics sl ch570
pls. try switching the speakers, if the sound switch from left to right or right to left , one of your speakers has an open circuit. check the wire for any open link or check the speaker for an open voice coil.
Jun 27, 2013 | Audio Players & Recorders
No sound from left channel on my Technics SA-R 230
May just be bad connections on the speaker relay. Flip the main board over, and check those connections. It is pretty common on these older models.
Jan 18, 2013 | Technics Audio Players & Recorders
One of my decks sound louder than the other
I'd say the cartridge is getting tired. Swap the head shells with carts and test. Cheers john. Styluscity
Nov 27, 2012 | Technics SL-1210 Turntable
Car starts fine.. However, when I slow down to turn, or stop at a light it dies.. The car always starts back up, but it runs really rough till I hit the accelratoragain then it dies the very next time I...
Improve the Fixya.com experience for everyone by voting!
It seems as though you need an Idle Air Control Valve. Don't buy one from Advance Auto because of the price.
9k=
This small $45 item performs the following functions:
• Regulates the amount of air entering the engine during idle.
• When not replaced, vehicle could experience high or low idle, engine dies at idle and/or severe high idle possibly causing internal engine damage and safety issues.
If you need assistance in replacing the valve, Wells offers extensive application information and technical support via its Tech Line at 1-800-558-9770, as well as in-depth product and repair videos at www.wellsVE.com and through the "Wellstech" channel at www.YouTube.com .
All the best
Ben
May 29, 2011 | Dodge Avenger Cars & Trucks
Drop out of left channel, Adcom GFA5802
It sounds as if there is a broken solder joint somewhere that slowly opens up with heat. The other possibility is that an input or driver transistor is dying. Since the whole channel is dying, I would guess the broken joint and/or dying transistor are near the very input of the channel.
A tech can very easily find the spot by playing the amp until it starts to die, then spraying small bursts of freeze spray, one component or area at a time, until the amp suddenly comes back to life.
Aug 13, 2008 | Adcom GFA-5802 2-Channel Amplifier
Mitsubishi HS-412UR - Audio - Right Channel Not Working Properly
One of the strangest things that has happened to both the consumer and the technical field has been the use of a flexible adhesive on many of these machines' circuit boards. The glue in question is vanilla-colored, and has a tendency to react to electricity by inducing capacitance, resistance, and in some cases, even causing inductance issues. The fix, of course, is to remove as much of this material as possible, and following right behind with a nylon-based retainer. Then, if the problem persists, a followup with tried and true technical procedures...accordianman
Feb 12, 2008 | Televison & Video
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Dec 02, 2007 | Technics SA-AX540 Receiver
Panasonic Vintage Technics Receiver Model Sa 8000 X Logo
23 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
