Question about AT&T 2256 Cordless Phone
Phone won't connect
We've replaced the batteries on our phone, but it still won't work. The power works, the answering machine works, but we cannot dial on the key pad or get a dial tone. The phone says "connecting" all the time.
  • Anonymous Apr 05, 2008
    phone will not connect
I had the same problem. I unplugged the base unit for several minutes. When I plugged it back in, the base unit reset itself and the handsets reset themselves to the base unit. You will have to reset the clock and any other features you use. My phone is a model E5908. Hope this works for you. Goos luck.
Posted on May 18, 2008
SOURCE:
Telstra 7100a home phone
Hi, It sounds like the batteries of the handset could be the problem.
Try replacing the batteries with other new batteries. I recently purchased a good brand of battery (not rechargeable), but they were down in their voltage straight out of the package.
Make sure the batteries are AAA NiMH batteries, and that they are charged for at least 16 hours.
Also check that you have inserted them the correct way +ve/-ve.
When you have inserted them, place the phone on the base and the handset should show you it is charging.
Jan 29, 2014 | Lands Phones
My LG cell phone doesn't turn on for me. I've tried lots to get it to work but it won't work! Plz help!!!!!!!!!
Hi,this problem is not a single question and doesnt have a single answer,all inside circuit include battery must be checked, may be the battery is gone may be mother board problem or break up maybe dust or humid problem and or even software problem,go to certified repair store to fix it for you
kind regards
Apr 17, 2013 | Cell Phones
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
Coffee bean light won't go out when full and coffee won't work
Hi coffee friend I have just answered this question. I think
After you have done all the cleaning you have done, you can try this: do check that all knobs correctly set. That the steam spout is closed. that the water tank sitter correctly
Disconnect from power, wait 2-3minutes connect again and hope for the best.
Kolbrun
Apr 16, 2012 | Solis Palazzo Espresso Machine
After having the phone company disconect the voice mail the answering machnine won't work
Hi there on this lovely nightt- Northenlights and all.
My first impression is that I am not surprised I think there is a connection between a voice mail and answering machine. I think you must reconnect.
Kolbrun
Feb 25, 2012 | Panasonic Lands Phones
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Jul 09, 2011 | Uniden Cordless Phone
All phones stopped working
Check up power supply / Battery.If battery operated replace with new one.Need to check the main unit battery/ power supply.
Sep 21, 2017 | Uniden TRU4485-2 Cordless Phone
Answering drops call when answering
DO YOU HAVE DSL ON YOUR PHONE LINE? IF SO THIS COULD BE THE PROBLEM
Jul 28, 2006 | GE 29869GE2 Digital Answering Machine
AT&T 2256 Cordless Phone Logo
318 people viewed this question
Top AT&T Lands Phones Experts
Ekse
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
