Question about Nordic Track NordicTrack Treadmill, A2550
Console of nordictrack c1750 is looping and won't start if it?
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: i have a nordictrack audiostrider 800 that i just
The way to tell if your NordicTrack digital console is bad is to troubleshoot it first. If nothing works, you've got a bad console. The digital console is an important part of exercising. A manual machine will still work even if the console doesn't, but an automated machine needs the console to work so you can adjust things like speed, resistance and incline. You also can't use programs or see your time, distance or estimated calories burned without a working console. The two most common reasons that a console will be dim, display bad results, or won't turn on are bad batteries and a problem with the reed switch.
  1. Replace the Batteries
    • 1 Replace the batteries first, if your machine has batteries. A manual machine such as the NordicTrack MTN 740 will not need batteries, and instead the console is powered by your moving the steps. Check your manual if you are unsure of which batteries to buy. Different machines will require different batteries. The NordicTrack Mini Stepper uses watch batteries, but larger machines will likely need AA or D batteries.
    • 2 Take off the cover to the battery compartment. Remove and discard the old batteries. Replace all of the batteries, not just one if you happen to have one good one. Align them correctly with the "+" and "-" signs as shown on the compartment.
    • 3 Replace the battery cover and attempt to turn on the console.
    Reset the Circuit Breaker
    • 1 Check the circuit breaker. A machine such as the NordicTrack CXT 990 will have a circuit breaker located on the front of the machine. The console will not work if the circuit breaker is tripped.
    • 2 Push the circuit breaker in if it protrudes until it sticks.
    • 3 Try to turn on the console. Check the circuit breaker for your house if this does not fix the console problem.
    Adjust the Reed Switch
    • 1 Inspect the reed switch as the information on the display will not be true if the reed switch is too far from the flywheel on NordicTrack machines such as the MTN 740.
    • 2 Unscrew the two M10 by 82mm button bolts on the right pedal bracket. Unscrew the two M10 nylon locknuts. Pull off the pedal bracket and set aside.
    • 3 Remove the two M4 by 38mm screws. Remove the three M4 by 25mm screws. Slide the right side shield off to expose the flywheel, magnet reed switch.
    • 4 Unscrew the screw that holds the reed switch in place but do not remove it. Slide the reed switch toward the flywheel but leave enough space that the magnet can move freely. Replace the shield and bracket
Posted on Nov 08, 2011
When I start my Nordictrack treadmill it immediately goes into looping. How can I fix this? It's only a year old.
If you wish to get some details about treadmill repair and calibration; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 16, 2016 | NordicTrack Exercise & Fitness
I have a NordicTrack commercial 1750 treadmill. My console contols do not work and the ifit screen does not complete startup. What can I do to troubleshoot the problem?
The Controls Are Not Working on a NordicTrack Treadmill ...
www.livestrong.com > Sports and Fitness
Jun 1, 2015 - The Controls Are Not Working on a NordicTrack Treadmill ... Many glitches involving the controls on the console can be solved relatively quickly with some simple .... How to Use the iFit Videos with My NordicTrack Treadmil...
Nordictrack commercial 1750 that Icon can NOT fix - YouTube
? 3:52
https://www.youtube.com/watch?v=ILBbzyUXn2Q
Dec 16, 2011 - Uploaded by gerg6060
Nordictrack commercial 1750 that Icon can NOT fix ... I'll NEVER buy another Nordictrack again, Smooth or ...
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...1...
NordicTracktreadmill is not working properly. (See. TROUBLESHOOTING on ... COMMERCIAL 1750 treadmill. ... Console. Book Holder. Key/Clip. Power Switch. Walking Belt. Foot Rail. Power Cord ... Set the treadmill in a cleared area and remove all packing materials. Do not dispose of .... Each workout automatically controls the speed.
Dec 28, 2015 | Nordic Track NordicTrack COMMERCIAL 1750...
My NordicTrack T5zi Walking Belt Treadmill won't
Very likely your console went out. I usually check for voltage running to the console (the wires in the back) and if it has juice but will not come on, I replace the console. As far as "why", usually it is power fluctuations, it can be as simple as turning on a high-amperage piece of equipment, or running too many electronics on the same circuit. I see consoles go out from low voltage more often than high voltage.
Nordictrack is an Icon product, you can download the product manual and parts diagrams at iconservice.com.
Feb 02, 2013 | Exercise & Fitness
Nordictrack c1750 firmware stuck in checking for updates?
Reset the machine, see the button in the instr. manual and proceed according.
God bless you
Dec 09, 2012 | Exercise & Fitness
Nordictrack ASR 630 display won't start
see the steps and fix it according. God bless you
Console 1
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Nov 18, 2012 | Nordic Track Nordictrack Ack Asr 630...
Nordictrack Commerical 1500 - Display Failure/Won't Turn On
There can be a few reasons,
Lume
LCB
Console
Is it under warranty ?
Jan 25, 2012 | Nordic Track NordicTrack Commercial 1500...
I have a nordictrack audiostrider 800 that i just replaced the console. now the resistance won't work. thoughts?
Oct 19, 2011 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Oct 29, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Treadmill, A2550 Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
