Question about Facebook Apps
Disallowed key characters - Facebook Apps
2 Suggested Answers
SOURCE: whenever i post on twitlonger, i get the page disallowed key characters. Why?
what is your yahoo or hotmail password
Posted on Dec 02, 2012
Timer and clock stppped workong
on some models, F0 error is a stuck keypad error. a stuck key will disallow entry of other keys. Model#?
Apr 24, 2016 | Kitchen Ranges
Dell manuals
I have Dell N 017F9Y keyboard, which has several keys with up to 4 special characters (e.g., ;, : apostrophy and degree symbols on one key) on them. The problem is - what keys (shift/alt/Ctrl or specific combinations of these) should be used to get appropriate character. There are 6 keys with 4 characters, 6 with 3 characters. Another example is when I try to put question mark using Shift lock it gives me ( ^ ) this character. The help is urgently needed.
Thanks..Kumar
Jan 10, 2014 | Computers & Internet
Keyboard characters disallowed
THe keyboard is defined in the Windows operating system. Please go back into the Control Panel and go to keyboard and adjust the settings with administrative permissions!
Jan 01, 2013 | Microsoft Windows 7 Professional Service...
When I go to one particular address, my computer screen displays the message, "Disallowed Key Characters." Help!
first of all check do you have static or dynamic IP Address this is becauz some time some dns or ip is blocked by some isp (sp. Govt.)
or do one thing click on this link http://anonymouse.org/cgi-bin/anon-www.cgi/http://www.parisjc.edu .
Dec 14, 2012 | HP Computers & Internet
I have my wep key, 11 characters, and internet at my own house. problem is: my psp says its invalid and it wont go in. im really lost and not sure what to do. hexadecimal what?
Hi, the WEP key you have should be incorrect, WEP keys have to be 10 characters, 26 characters or 58 characters.
Also, make sure you have entered your key correctly, when hexadecimal warning comes up it usually means that you have entered a character that is not A,B,C,D,E,F or 0-9.
Feb 28, 2011 | Video Game Consoles & Games
HOW TO CHANGE SSID
To change your Residential Gateway wireless settings:
  1. Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
    If the Home page does not open, check to make sure that you have no software firewalls blocking network access.
  2. Click the Home Networking tab at the top of the 2Wire Home page.
  3. Click EDIT SETTINGS located on the right panel (Status at a Glance) under the Wireless Settings heading.
  4. Change your wireless settings and use the following information if you want to change to a custom WEP key.
    64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
    128-bit hexadecimal keys are exactly 26 characters in length. (For example, 456FBCDF123400144445271730 is a valid string of 26 characters for 128-bit encryption.)
    64-bit ASCII keys are exactly 5 characters in length. (For example, GMODE is a valid string of 5 characters for 64-bit encryption)
    128-bit ASCII keys are exactly 13 characters in length (For example, 2008SUNSSWIN1 is a valid string of 13 characters for 128-bit encryption.)
Nov 08, 2010 | 2wire (1000-000057-000) Modem
Not able to connect the sons Nitendo DSi to the internet. They are asking for the WEP Key but on my home hub there is only a WPA Key. BT have told me to connect to you to ask for support.
If your using WPA and your Nintendo DS only supports WEP Encryption theres no way you can connect it to the internet. WEP encryption is different from WPA.
WEP key uses hexadecimal - using characters 0-9, A-F or ASCII format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
Example of WEP key encryption are:
*64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
*128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
*64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
*128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
WPA Key is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
To resolved the issue you have an option to change the WirelessSettings on your router to WEP instead of WPA since WEP is also a secured netwrok. however you need to keep in mind that if you change the encryption you need to configure all othere device connected to the router via WPA and change the settings to WEP.
Thanks for using Fixya
Aug 02, 2010 | Computers & Internet
How do i make a character that looks like a 7 but vertical portion is straight
The answer is ALT + 191
To obtain an ALT Character:
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear
Found here... http://www.tedmontgomery.com/tutorial/altchrc.html
You will find all the special characters there.
Thanks,
John C.
Sep 17, 2009 | HP Pavilion dv9000z Notebook
I need an 8 character referral key for microsoft office professional 2007
I need an 8 character referral kay for microsoft office professional 2007
Oct 01, 2008 | Compaq Presario 5000 PC Desktop
Facebook Apps Logo
105 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Facebook App Expert? Answer questions, earn points and help others
