Question about Kenmore Refrigerators
My kenmore model number 795.75209402 was stored for a year and was replugged after sitting in new place for 3 days. it won't cool. it is running, but it isn't cooling. any ideas?
SOURCE: Cooling Problem
make sure it is pulled away from the wall and all sides are clear.
Posted on Apr 25, 2007
SOURCE: GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Posted on Jun 24, 2009
  • 93 Answers
SOURCE: Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Posted on Sep 13, 2009
dmftrucker
  • 1922 Answers
SOURCE: Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Posted on Nov 01, 2009
Testimonial: "That's what my fridge is doing? Thanks for the help."
arikrom
  • 528 Answers
SOURCE: refrigerator seem to not cool to the proper
your problem is in hte freezer area open the panel in your freezer you might need a new heat element or a new thermostat unit... not so bad to do or check...
arik from 911.servicetoday.com
Posted on Jan 01, 2010
Kenmore side byside model# 363.9565482 does not cool/freeze after 3 day power outage .lights on & fan runs .tried unplug/replug & cleaning coils still not cooling .How do I fix?
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 30, 2011 | Kenmore Side by Side Refrigerator
The compressor runs and freezer is cold, however the refrigerator side isn't cooling well. Doesn't feel like any air is blowing in the fridge, only the freezer. I tried turning off/resetting the system...
Your model numbers are a waste of time...
Kenmore 5522 / 655224 / 55222 / 55229
Side by Side Refrigerator... PICK One...!!!
"The" fan...??
There should be TWO fans running...
and the FAN that REALLY make the difference in your
described symptoms ... will not run with the DOOR
open (your evaporator fan).
Possible issues:
Fan motor, blades/air blocked by ice, broken blade,
defective door switch or control board...
I always preach... giving a troubled refrigerator
a THREE DAY defrost... but the other day I found
a solid ice block sitting all SNUGGLY in the middle of
an evaporator...
If you are not willing to do that... (3 day defrost)
open it completely and have a REAL GOOD look
around the EVAPORATOR & FAN.
Never use HOT air... soft plastics can be easily ruined.
Take your MODEL NUMBER...
And look on:
Appliancepartspros:
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
repair clinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Happy hunting...
Carnac the Magnificent
Aug 16, 2017 | Kenmore 5522 / 655224 / 55222 / 55229 Side...
My kenmore fefrigerator not cold anymore, what should I check first pls!
Hi and welcome to FixYa. I am Kelly.
First check the freezer compartment for signs of ice build up. If the unit is running and not cooling. If you note ice build up do the following.
1. Unplug the unit.
2. Remove the contents of the freezer compartment.
3. Place a fan blowing into the freezer compartment of about 2 hours. (Makes a water mess. Mop and rags required)
4. After 4 hours wipe the internal cabinet dry.
5. Plug in the unit and let run about 30 minutes.
6. Reload freeezer contents.
This is a manual defrosting procedure. It will only provide relief from the symptoms of no cooling for around 2 days. If the manual defrosting returns the unit back to normal temps then you will need to have the unit serviced and the automatic defrost circuit repaired.
The problem can be
1. Defrost control,
2. Defrost heater element,
3. Wiring, or
4. The defrost thermostat.
Any one of the 4 can cause the problem.
If the compressor is NOT running at all the problem can be
1. Defrost thermostat.
2. Defrost control
3. PTC start relay or the KliXon thermal overload (2 part Assy)
4. Run capaicitor
5. Compressor
6. Temp control.
You did not provide a model number in your post so all of the above are GENERIC terms. If you need specific information you will need to respond with your model number.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Kenmore Refrigerators
I have a freezer that won't cool after storage
It could have lost the refrigerant very slowly or there could be othere issues... need to put gauges on there and see for sure what is going on...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Feb 13, 2010 | Freezers
Replacing a relay switch on a Kenmore Side by Side
The start run relay kicks the compressor on. If your compressor is running this is not your problem.
There are a number of things that can cause a fridge not to cool. A bad defrost system.. Check to see if you have ice build up in the freezer, or a lot of frost. Also a bad compressor. The relay switch sits on the compressor at the back of the fridge. If you put a new relay on and it won't start the compressor you have a bad compressor. Most compressors are warrantied through the manufacturer for at least 5 years. So if it's that call the manufacturer for replacement.
Apr 15, 2009 | Kenmore Refrigerators
Kenmore Refrigerator not cooling
No you don't need to change the compressor you need to change that fan and you need to change the start relay overload and capacitor that goes to the compressor. What is the model number of your refrigerator so I can look up your parts
Apr 02, 2017 | Kenmore Refrigerators
Old Upright Kenmore Freezer Help , please
If it is a shelve it is made for storage. A sign of imminent death on these old freezers would be its ability NOT to reach a low enough temperature when running. The older systems had heavier metals in the construction including the cooling systems. Some tips on keeping it happy would be to operate it in a place where you would be comfortable to sit for an extended period of time.
Jul 06, 2008 | Freezers
Kenmore Elite Top Loader (Model 110.16982500), 2.5 years old leaves white sheets with black dots and 1/2 inch black lines in varied places.  Does this for days and then not at all for several weeks. Using...
Try using the juice from a fresh lemon to clean the machine internally, where your washing sits. Preferably wipe the lemon on the surfaces that are contaminated.
Apr 04, 2017 | Washing Machines
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
