Question about Lavelle Industries Korky& Universal Toilet Repair Kit
Anti siphon hardware korky: how do you turn it off if the toilet is overflowing? I've been able to lift up every other style of hardware to stop the water so the bowl doesn't overflow when clogged.
2 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: korky anti siphon 528 is
If the water is reaching the tank overflow tube, the float valve is not stopping it fully. If the valve is new or not too old and you have instructions or know how to disassemble it, you can flush it to ensure there is no debris in the valve or on the seat. Although the manufacturers recommend this, I have never found anything on the seat.
If you can't do this, a new float valve assembly must be installed.
Gary
Posted on Feb 26, 2011
Our local housing inspector says a toilet fill valve must be anti-siphon. I have Kohler k-9262 fill valves in my bathrooms. Are these anti-siphon models?
the fill valve is under constant mains pressure so it will not siphon out. However if there is a problem you can buy a non-return valve from your local hardware/plumber shop and fit it in the line between the cistern tap and the cistern
Jan 28, 2015 | Kohler Home
Tip
How to fix a refill valve
  • Brass-style toilet refill valves can often be repaired. To take a valve apart, remove the lever's screws. This allows you to lift out the float arm and valve plunger. Check the flat rubber washer on the end of the plunger. If it's worn, you can pull it out with pliers and either turn it around or replace it. This procedure usually corrects an overfilling problem. Next, reassemble the valve. If the tank continues to overfill, check to make sure the operating lever at the end of the float arm is functioning properly.
  • New refill valve. To replace the entire refill valve assembly, first turn off the water supply. The tank should then be flushed and sponged out, as detailed previously. Remove the inlet nut and riser tube from the bottom of the refill valve beneath the tank. Hold the refill valve inside the tank with a padded locking plier/wrench to keep it from turning, and remove the nut beneath the tank. With the nut off, the refill valve assembly can be lifted out and a new one inserted in its place. Follow the exact instructions included with the unit you purchase.
  • Finally, reconnect the riser tube and turn the water on. The tank should fill, allowing you to adjust the water level according to the instructions that were included with the valve.
  • Anti-siphon valves. The best refill valves offer anti-siphon protection. In fact, this may be a requirement. This protection prevents back siphonage of toilet tank water into your home's potable water supply system if a vacuum occurs in the toilet's water supply system. Whether or not this is a code requirement, the anti-siphon valve is a good idea to protect your family and public health.
on Jan 16, 2010 | Plumbing
Anti siphon toilet water float wont ajust
mike I guess your toilet must be ok by now since your sept posting.GL
Sep 06, 2013 | Korky Universal 3in Flapper 3060BP
Korky anti-siphon. Tank water slowly drops, accompanied by a hissing sound. Then, after dropping about 1/2 inch, it refills. Wha?
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl slowly...causing the fill valve to run every few minutes or so. hope this helps but if you need anything else just text me here:)
Jul 29, 2011 | Lavelle Industries Korky& Universal Toilet...
Korky anti siphon 528 is leaking, water is high and leaking in drain pipe
Gary
Feb 26, 2011 | Lavelle Industries Korky& Universal Toilet...
The toto toilet keeps running over the overflow tube in the tank. I cleaned the valve which worked for a while but now is back to running. Should I replace the gravity valve?
If you can lift the float arm and it stops the water flow into the tank then the float arm needs to be adjusted. The proper adjustment will stop the water flow when the level is between 3/4" and 1" from the top of the overflow tube. The newer style valves have an adjustment screw that is easily located and can be adjusted without any dis-assembly.
Feb 19, 2011 | Toto Home
Replace flapper valve in ultramax
Your Toto has the "G-Max" flush valve system. The Korky/Lavelle folks have a carded replacement flapper #2021BP for it. It is red in color and the only generic flapper that will work on your toilet. While it may look the same, do not confuse it with the blue flapper #2022BP. Known as the PowerMax flapper, the blue color is to distinguish between the two and the flappers are totally toilet specific. Let your fingers do the walking and locate a hardware store near you that carries the Korky/Lavelle brand or it can be ordered online from several places using the part number for your search word.
If the fill valve ever stops filling correctly, the Lavelle "Quiet Fill", #528BP, is what Toto uses in most of their toilets.
Nov 09, 2010 | Toto UltraMax One Piece Toilet, 1.6 GPF -...
Water seems to keep running very slowly, can't hear it, after it apparently stops after a flush. Eventually reaching the over flow tube in the tank. I have replaced the Toilet fill valve twice, The first...
Rossouw R. im a plumber.
Were the flexi hose go in to the toilet and conect up to velve thread tape. unscrew the flexi hose and then the plastick nut holding the velve on to the sistern.
put the new velve in and bobs ur uncel.
Its very easy, just look were the 2 seal rubbers are when u remove it, may be 1 rubber.
and the flout of the velve will be a cup or ball, thast ajast that tothe right water level, u will c were the flout or ball is on new velve there will be plastick with bumps un it [most commen] if not let me know bt around that area u should find somting to adjust the hight. sorry for spelling errors, im a plumber nt a english major lol
plz let me know if u get in a rut .that is realy the onley solution.
Jun 11, 2010 | RTO Fillpro Anti-Siphon Toilet Tank Fill...
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
Kohler two peice toilet the water just circles and will not flush.there is plenty of water in holding tank that run through
These models need to have a flush valve flapper that has a styrofoam float on the lift chaninof the flapper. Go to hardware store or home improvement store and get a 'Korky brand toilet tank flapper with float 'ball". Cut the rubber ring piece away from the flapper and you don't need it (see cut here marks on flapper). Install flapper and adjust the float fairly close to the flapper.
When the water level drops in the tank and reaches the level of the float on the opne flapper, the flapper quickly closes causing the toilet to have a "surge" of siphon action which forces the water in the bowl to be drawn out.
Jun 29, 2009 | Kohler K-3422 - Wellworth Elongated...
Lavelle Industries Korky& Universal Toilet Repair Kit  Logo
59 people viewed this question
Top Lavelle Industries Home Experts
Donni Steen
Tom Chichester
Are you a Lavelle Industries Home Expert? Answer questions, earn points and help others
