Question about Interphone F4 Single Stereo
F4 interphone emits 3 tones every couple of minutes - what is it trying to tell me?
Casio 3426, tone sounds every 20 min.
http://protrek.casio.com/resource/manuals/module_3246.pdf
At the top of page 3 is instructions to change the time. Notice in the diagram there is a step in which you have the choice to turn off the tone. Try that.
Secondly, try entering alarm mode, as described at the top of page 2. I suspect you have some alarm set. Remove it if you find it there. Note that you only have a couple of minutes in which to make the alteration before the watch automatically kicks you out of the alarm mode.
Jun 16, 2017 | Casio Music
I have two interphone headsets that we have used for 4 years. We have begun to only have battery life for 2-3 hours. Is there a way to change batteries? Any help will be appreciated. They have...
With the BT Interphone that I have (~4yrs), one unit's battery would last <1hr. I carefully cut the rubber case along the bottom mold mark to remove the circuit board. The battery is a 3.7v 600 mah lipo. These are available from a variety of hobby shop sources, but are 650mah. $7-15 ea. Very careful cutting of the rubber case and minimal heat soldering is critical in installing a new cell. I'll use 3m weatherstrip adhesive to close it up.
Otherwise a complete new 3rd generation BT set-up is about $90 online. Mine still works good though.
Aug 15, 2011 | Blueant InterPhone Wireless Headset
I get an error code e1 and have cleaned and replaced the filter. Runs for a couple minutes then shuts of with same message. Any ideas?
THIS SHOULD RESET IT
1 DISCONECT THE POWER PLUG FROM POWER SUPPLY 2 CLEAN FILTER 3 HOLD DOWN THE POWER ON/OF BUTON ON THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTILL IT EMITS A BEEP SOUND FOR APROX 5 SECONDS 4 DISCONECT POWER AND PLUG AGAIN
IF THAT DOES NOT WORK 1 DISCONECT UNIT 2 HOLD DOWN THE MODE KEY ON THE PAD OF THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTIL IT EMITS A BEEP SOUND APROX 3 SECONDS THE UNIT WILL START. 3 STOP THE UNITS OPERATION BY PRESING ON/OF 4 RESTART UNIT.
BEST OF LUCK
May 31, 2011 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
Unable to receive sound from interphone F4 when calls were made. Able to make call or receive calls, but cant hear anything , the other caller can hear you.. speakers checked ok, can hear MP3.. Please...
I also did have this problem with my SE W715.
I did talk to Cellular Italia S.p.A and did get this answer that did solve this problem.
Make the pairing as usual.
Make an phonecall.
When you are online press MFB button again and your cellphone will switch from cellphone speaker to headset speaker.
This you only have to once at the first pairing.
/Poul
May 08, 2010 | Sony Ericsson W910i Cellular Phone
Every time I turn on my air conditioning a powerful stink is emitted from the vents. It's really bad now - it used to be just the first couple minutes, and now it's for a solid 10 minutes every time. It...
Get the cores cleaned and be sure that the drain is clear and flowing.
One thing to do is turn off AC and still blow air through it, on high, for 2 or 3 minutes at shutdown. What you are trying to do is dry the evaporator of condensation. MUCH less smell on next power on of AC.
Oct 05, 2009 | 2006 Volkswagen Rabbit
Tomtom 930 will not pair with Interphone 4
Sadly, it's not possible to do what you want.
The lower cost, non bike specific units only have limited BT capability - so that they can act as a handsfree for a phone - which is what Interphone does, so there's fundamental incompatibility.
The best units with Interphone are Garmin Zumo 550 (NOT 660) or TomTom Rider 2.
Only one person can hear the gps (and the range is only 10m from Interphone to gps)
Your best bet could be to get phones with gps capability - it's free on some of the new Nokias.
Jul 14, 2009 | Tomtom Navigator Bluetooth GPS Receiver
Can't get handset to register
After each registration of a handset, you need to hold the page button on the base for 5+ seconds. If you then get an error tone, you'll likely have to return the phone due to a hardware problem. What did you do?
Apr 05, 2009 | Uniden Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
Dect 6.0
Hi :I have the same problem and the dealer couldn't help me .I replaced the battery but that wasn't the solution.Glad to see i'm not the only one with this problem
Mar 22, 2008 | Uniden Cordless Phone
Favorit 44070Vi 3 short warning tones
It is most likely to be the wash pump leaking underneath, the float switch lies underneath the dishwasher, if you tip it back slightly you will probably find that water will leak out, that will prove that it is leaking and it will probably work a couple of times after this but it isn't the answer i'm afraid, a wash pump is not really the sort of thing you should tackle yourself.
Nov 26, 2007 | AEG 23 in. Favorit 44070Vi Built-in...
Interphone F4 Single Stereo Logo
43 people viewed this question
Top Interphone Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an Interphone Cell Phone Expert? Answer questions, earn points and help others
