RCA truflat will not pick Up the Antenna? What do I need to do?
3 Suggested Answers
  • 48 Answers
SOURCE: rca 14" truflat
really depends on the model. I've got a 2005 26" RCA truflat that has both digital and analog ota tuners--I can pick up off of rabbit ears OTA broadcasts, as well as via coax cable (cox cable) any of the unencrypted clear digital channels (QAM). Just can't handle the encrypted channels. If there are multiple coax inputs, check their labels--if labeled digital, likely that you've got a QAM digital tuner. Also, in the menuing system, channel scan--does it identify signal type as selectable digital/analog?
The surefire, get the model number, goto RCA.com website, download the user manual.
Posted on Mar 14, 2009
SD Tech
  • 14553 Answers
SOURCE: I NEED A RECEPTOR CHANNEL FOR RCA TRUFLAT TV MODEL B27TF680 SERIE No. B406L914N
Many parts stores sell the fitting but it takes some real skill to install it and many times the tuner itself has the fitting built into it so the tuner has to be removed to attempt this.
what is your skill level?
Posted on Dec 19, 2012
My RCA truflat is stuck on MONO, I have lost the remote ..how do I get it off of MONO?
Push the tv menu button on the front of the tv set.Go to Audio setup used the channel buttons UP and DOWN to pick ur choice.Can't do this manually.Try website like Remotes.com to buy an tv original remote.
Aug 08, 2011 | RCA TruFlat 27F520T 27" TV
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
I have an RCA Truflat that began turning itself off today. Sometimes it will last 20 minutes, sometimes a few seconds. I'm broke..no way can I get it repaired..any ideas as to what's going on?
possible cold solder joint(loose connection). try the old method of picking it up and slightly moving it. hit it. if it seems to affect operation, just simple soldering on power supply and deflection will fix it. 50/50 chance
Nov 14, 2009 | RCA TruFlat 27F520T 27" TV
Is the rca true flat tv able to be used by putting up an antena -or will we need a convertor box ? currently we have direct tv and are thinking about canceling it and use an antena.
This model does not have a built in HD tuner (ATSC Tuner). You would need an HD antenna (that is a more recent antenna that receives UHF) and an HD converter box to get the newly broadcast HD signals.
Nov 06, 2009 | RCA TruFlat 27F520T 27" TV
Can this tv pick up the new digital off air signals? i just bought an indoor digital antenna and no channels will come in. do i need a converter box?
You need a digital box. If the TV is connected to the Digital Box & you have it setup correctly you should be able to get Digital channels. An internal antenna is not the best idea unless you are in a good reception area.
Oct 21, 2009 | RCA TruFlat 27F520T 27" TV
I have a rca digital ready tv,I scanned for the new channels and I received all of them except for 1 of our local channels.Why would I not receive this one?
Hi, There could be a couple of reasons, primary probably is signal strength. Depending on your antenna direction and the transmitter location it may be a dead spot which can be fixed by moving the antenna slightly and rescanning. If you need further help please get back to me. Good Luck! Hope this Fixsya!
Feb 26, 2009 | RCA TruFlat 27F520T 27" TV
Rca 14" truflat
This set was made before it was required to have digital tuning built in. You would need a digital converter box if you want off-the-air reception. (The federal program at www.dtv2009.gov that is giving $40 coupons toward purchasing a converter is out of money right now and is only putting people on a waiting list. It also looks like the changeover to digital is going to be delayed again, so you might not need to worry about it for a while longer.)
Feb 06, 2009 | RCA 27F534T TV
Blue screen on all channels RCA TruFlat
This is NOT the problem. video games, dvd player and cable connection are all all a blue screen with sound
May 14, 2008 | Televison & Video
RCA TruFlat 30-something inch
what chassis is in your set.look on rear panel ./st
Dec 09, 2007 | RCA 32F530T 32" TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
