Question about Lucent Legend MLX-28D Corded Phone
Console Problem We recently switched phones from one extension to another. Now the added console that shows who is on phone isn't lighting up, but the bottom ones (400, 450, 500) are. Is there an easy fix?
    Novelist:
  • 201 Answers
When you switch phones the system does not know this. All programming is stored in the system, not the phones. If you swap phones of the same model nothing should change. If you put a phone in with different button configurations then things very well may change.
It's not an easy fix. The phone system would need to be re-programmed for that phone port.
Posted on Jan 28, 2008
SOURCE:
At Receptionist phone- shows a solid green light on rights side of a specific extension- at that extention it is a green flashing light, but no message- looking to see how we get rid of the green light at...
On the attendant phone:
1. Press the Message key on the Attendant Add-On Console.
2. Press the DSS key on the Attendant Add-On Console that is associated with the station where Message Waiting is to be canceled.
May 12, 2011 | NEC DTH-8D-1 Corded Phone
Every extention on the console is showing with the red led light, as if the lines are busy. Therefore I cannot transfer calls, when in actual fact, the lines are not busy
ouch, sounds bad...
possibilities~
1) everyone has DND turned on if so have them disable their call forwarding entirely (intercom*7100)
2) your buttons are all suddenly programmed wrong, reprogram them to the correct extensions
(press "PROG" then the button you want to program, press " 1 " then the extension number, then enter)
3) major error with the system, have a serviceman come out and take a look
Jan 04, 2011 | Panasonic KX-T7630 Corded Phone
Hi, I've just added and expansion card in my panasonic tes 824. but the problem is although the additional extensions are working. no additional CO lines are being detected. when i go to the CO line...
No. At the very minimum, you need to go to program 400 (3.3 in the U.S. Maintenance Console) and turn on the lines. Access may have to be enabled from each extension for both outward and ringing programming might have to be added.
Carl
Oct 30, 2010 | Panasonic KX-TA824PK Phone
My phones only light up on my panassonic business phones
If you have a PTPM or the maintenance console, you can program ringing. It's a dealer only product in the U.S. Incoming calls are made to ring ICD (incoming call distribution) groups where the ringing is controlled per extension. In our version, even the manager does not have access to that level of system programming.
Apr 05, 2010 | Panasonic KX-T7633 Corded Phone
Ringing everywhere
If it used to work and stopped, I'm guessing the system is no longer in the DAY mode. Each system tends to program differently and the 7730 phone can be plugged into one of about 18 different Panasonic systems.
From the main phone, try dialing 780#. If it beeps and says DAY MODE, it was the right command :-) Now test the lines and see if that fixed it.
If it doesn't work, please go to the phone closet/back room/attic/whatever and grab the model number of the phone SYSTEM and post back.
Carl
May 11, 2009 | Panasonic KX-T7730 Corded Phone
Need to change extension names on a MLX-20l phone
http://dstech1.com/changing-the-name-on-an-extension/
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected.
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
Note: When programming on the system programming console, use the buttons next to the display to specify the letters A through I and punctuation. Use the line/feature buttons to specify additional alphanumeric characters for labels. Use the template provided with the System Programming console to see which line buttons correspond to which alphanumeric characters,
Jan 13, 2009 | Lucent Merlin Legend MLX-10D Phone
Lucent MLX-20L Extension Edit
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Dec 22, 2008 | Lucent Merlin Legend MLX-10D Phone
Mitel superconsole 1000
We have the same problem at our hotel.
You can't fix it at the console, you need to go to the room and unplug the guest's phone from the wall for 10 seconds... reconnect and it is fixed.
Aug 23, 2008 | Lands Phones
Adding New Extensions Labels
go to support.avaya.com and search MLX-20L, you can download or view the pdf of the manual
Jul 02, 2008 | Lucent Merlin Legend MLX-20L Phone
Console Lights
You can do a self test by pressing buttons in this order: Intercom, speaker, *, 0, 0 The phone will make noise and all the lights will flash. If all the lights are working in self test but no in normal operation, then it's probably a programming issue. Have you had any other problems or mysterious changes in the system? Possibly after a power outage or lightning storm??
Jun 06, 2007 | Lucent Legend MLX-28D Corded Phone
Lucent Legend MLX-28D Corded Phone Logo
80 people viewed this question
Top Lucent Lands Phones Experts
Ekse
socrtwo
Level 1 Expert
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
