Question about Kitchen Appliances - Others
Foodsaver V3815 not vacuuming out air - Kitchen Appliances - Others
2 Suggested Answers
  • 86 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
Door to my foodsaver is stuck on one side. It's shut. How can I release it? Is there a release button anywhere?
Trouble with Food Saver Brand - Survival Podcast
thesurvivalpodcast.com > ... > Food Preps > Processing Food For Storage
Aug 15, 2010 - 17 posts - ‎13 authors
We have been using our Food Saver Vacuum sealer we bought ... connects somehow got stuck open and therefore the bags would not ..... I've had the FoodSaver V3840 for about 10 months now and thus far it has been great.Missing: door
FoodSaver Repair - YouTube
? 8:22
https://www.youtube.com/watch?v=jguFiF0Rouw
May 21, 2014 - Uploaded by Kelly Kimble
Repair a FoodSaver that isn't drawing out air anymore. In this case, its ... Vacuum Sealer Troubleshooting - Duration: 10:25. katzcradul 52,345 views. 10:25 ... How to Food Saver Lemon Juice or Other Liquids - Duration: 4:56.
[PDF]Use and Care Manual - Home Depot
Jan 25, 2016 | FoodSaver Vacuum Food Sealer - V3840
Foodsaver V3460 vacuum runs and sounds like it has reached the end of the cycle then seals bag.
then you do not have the bag in proper place in the sealer , mine has never failed .
Aug 05, 2015 | FoodSaver V3460 Vertical Vacuum Sealer,...
V3420 foodsaver will not suck out the air
Is the motor still running?
If so it sounds like a blocked pipe
Aug 09, 2014 | FoodSaver V3420 Smart Seal Vacuum Sealer...
Why is my Foodsaver V2440 motor noisy while vacuuming bags?
This is normal it means that its just pumping air out of the bag but if it gets too loud and its not pumping air out of the bag then you might need it looked at soon
Jul 12, 2014 | FoodSaver V2440 Advanced Design Vacuum...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Doesnt vacuum all the air out
Your Product Manual for the Tilia Foodsaver Food Sealer Vacuum V2240 is available here:
http://www.foodsaver.com/Manuals/MANUALS/T000-32030_44_65900646.PDF
Please review all the Tips for Successful Vacuum Packaging. You may find some pointers that will you remove all the air.
Mar 26, 2011 | Tilia FoodSaver V2240
My Food Saver V3835 will not seal canisters. It seals bags AOK but there appears to be no vacuum generated through the extension tube. We have tried several different canisters and covers. I have also...
The negative pressure is very slight and almost not detectable when using canisters for food storage. Once the system is activated, and allowed to run until timed out, the canister should have pulled all the oxygen from the canister. Foodsaver only canisters are designed for the V3835 for vacuum sealing.
How to Vacuum Package Using Your FoodSaver® Vacuum
Packaging Canister
NOTE: FoodSaver® Vacuum Packaging Canisters can only be used with
a FoodSaver® appliance that has an Accessory Port. Please check your
QuickStart Guide to see if your appliance has one.
1. Place your FoodSaver® appliance on a fl at, dry surface and plug the power
cord into a standard electrical outlet.
2. Place the item(s) to be vacuum packaged inside the canister. Leave at least
one inch (1”) between the contents and the rim of the canister.
3. Wipe rim to ensure it is clean and dry.
4. Place the lid on top of the canister. If the canister has latches, put them
in an upright position so that the lid fi ts on the base. Push the latches
downward until they snap into place.
5. Insert one end of the Accessory Hose into the Accessory Port on your
FoodSaver® appliance.
6. Insert the other end of the Accessory Hose into the hole on the top of the
canister lid. Twist the gray tip of hose while inserting to ensure a tight fi t.
7. Follow the steps for vacuum packaging as outlined in your QuickStart
Guide.
8. Remove the Accessory Hose from the Accessory Port on the appliance
before vacuum packaging in FoodSaver® Bags.
Allow hot foods to cool to room temperature before vacuum packaging. Otherwise, the
contents may bubble up out of the canister.
How to Open the FoodSaver® Vacuum Packaging Canister
To open, press and hold down the gray rubber button in the center of the lid
until you no longer hear air escaping. This will release the vacuum and allow you
to easily remove the lid.
Sep 04, 2010 | Microwave Ovens
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
Nov 17, 2009 | Tilia FoodSaver VAC420
Kitchen Appliances - Others Logo
133 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
