Question about Patton PUH680-U Utility Heater
I need the high/low rocker switch foir milkhouse space heater
2 Suggested Answers
SOURCE: I need the lighted switch on front of Patton
MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
Posted on Dec 11, 2012
I need the lighted switch on front of Patton milkhouse space heater model puh680-u but can't track down web sight to order.
May 22, 2010 | Patton PUH680-U Utility Heater
Great Little heater: I need the Off-On Rocker Switch
go to radio they have many diffrent rocker switches if you cant find it there then call me 985 210 7291 i will get you one cheep ok jason
Apr 09, 2010 | Vornado EH1-0014-01 Compact Heater
I need a thermastat
If it's for the milkhouse style heater you show in this picture then go by a new heater, they are very cheap and the thermostat would certainly cost more then it's worth. I bought a heater like the one in the picture for around $13.00 at ACO Hardware wirth low, med, high wattage settings and with thermostat of course. A thermostat would likely cost at least $10.00 plus shipping so what would you do?
Mar 03, 2010 | Lakewood 792S Utility Heater
Del-Rain 1500V ceramic heater switch.
is it a little rocker switch ? if so any local hardware store, like HD, or Lowes, or any appliance wholesaler will carry these switches, or try online to the manufacture, hope that helps
Jan 20, 2009 | Del-Rain 1500-V 1500 Watt Ceramic Heater
Caution light comes on,rarely used heater. any thoughts?
Try calling 1-866-876-4332 ext 224 for tech help, it worked for me.  I only needed a temp
setting/off switch to fix mine.
Oct 21, 2008 | Pelonis WM-HO202C Oil Filled Radiator...
Switch
Try this link   http://www.nelsonappliance.com/Space+Heater+Parts.html
Mar 24, 2008 | Lakewood Oil-Filled Electric Radiator...
Patton space Heater Model # prh-5
check that the rocker switch inside isn't stuck, when the rocker swings it shuts the unit off. if it is full of dust it may be stuck. may just be bad.
Nov 12, 2007 | Patton PUH680-U Utility Heater
Patton PUH680-U Utility Heater Logo
53 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
Jay Finke
Jay Finke
jeff5may32
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
