Question about LG 42LC2D 42 in. LCD HDTV
I have a 42lf11 and the picture is not showing right I see the shows fine but its showing all types of colors
My panasonic plasma tv 32inches is show a gray color picture at d middle of about 4inches from top to down.and the other both side picture is fine wat can i do
Sounds like damaged COF [Chip On Filim] strip. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 06, 2015 | Panasonic Televison & Video
Color is not right. no red or green, but blue and yellow show up fine.
open the back cover of your tv you will see the color amplifier board,this board is the small board attatched to the picture tube...use a soldering iron to resoulder all the components in there and the color will be corrected.
Jun 13, 2010 | RCA F32650 32" TV
I have a samsung hdtv and the component 2 does not show the video in color...it only shows in black and white but in component 1 it is fine.if i use component 1 for dvd player it works fine with color and...
pls.set compnent 2 is on and set menu key on remot cantrol select system menu and see on display colour system is not proper . re set colour system is select AUTO and see the pictur is normal and ok.
Nov 10, 2009 | Samsung DLP HL-P5663W 56" TV
Hitachi 43FDX15B TV
Symptom: DARK PICTURE OR MISSING COLOR
Cause: CLEAN SPARK GAPS, CRT PINS AND SOCKET ON CRT PWB
May 22, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Model# AV48WP30 Picture show double vision. Colors cant be adjus
you need to replace the convergence ICs and associated resistors you can get the repair kit at the following link for your model which contains the two ICs and all the feed resistors plus step by step instructions with detailed photos how to do the repair. Heres the link to the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Mar 05, 2009 | JVC AV-48WP30 48" Rear Projection...
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Red color absent from projector picture
try to use another vga cable connector ther might be a cut on the red color signal try to move the connector form left to right until it gives you the red color if it does change your vga connector hope this help you on your problem thanks
Feb 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have an 2G MP3 player .
The files are in the wrong format - use Mp3 format only
Aug 10, 2008 | iLO MP3 Player
LG 42LC2D 42 in. LCD HDTV Logo
18 people viewed this question
Computer Repairing
Computer Repairing
