Question about Maytag 30" Self-Cleaning Freestanding Gas Range - White
I have a Maytag natural gas stove Model #MGR5755QDW. I used the broiler the other night and later we heard a very loud ping sound and couldn't determine where it came from. It sounded like a breaker tripping or something electrical. However, I turned on my oven tonight and it will not heat (automatically shows 100, there is a clicking sound as though something is turning on, but it never heats at all). The stove burners all work and the broiler actually still works...any thoughts? Thanks!
SOURCE: Oven burner doesn't light
Replaced the ignitor on mine 10 mins ago.... Works like it's brand new. You have to remove the bake pan in the bottom of the stove, remove the drawer, and the sheet metal shield protection the connection. Entire job was 10 mins.
Posted on Oct 22, 2008
  • 105 Answers
SOURCE: My maytag gas oven model #MGR5755QDW makes a loud
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Posted on Apr 08, 2009
shinn8
  • 85 Answers
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
Posted on May 18, 2009
shinn8
  • 85 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
  • 42 Answers
SOURCE: Gas stove works, but oven does not
A gas oven will have some built in safety devices. Assuming that you have an electric pilot light sparking device, anything in the pilot light circuit could cause your problem
The oven does not "want" to turn the gas on unless there is an operating pilot system.
Since you never smell gas, but gas is available, then something in the pilot light circuit sounds like the culprit.
It could be as simple as carbon build up on the igniter or an internal fusing mechanism.
If you can get into the oven to the igniter, you could try cleaning the unit with a plastic scrunge.
I'm going to guess that this is not going to respond well to 'home grown' measures and that it will require replacement of parts.
Perhaps it is time to bite the bullet and call in repair......
good luck
Posted on May 20, 2009
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
How to remove a Maytag gas stove oven door (Maytag Model # MGR5755Qwd)
Hi.
Before removing the door you need to release the lock on the oven door hinges. Door hinge locks are slide mechanisms or pins located on top of the hinges Once lock is released you will be able to pull out the door by opening it a bit, then lifting it up and pulling out.
Here parts and diagrams for your oven: MGR5755QDW.
Regards.
Ginko
Sep 09, 2011 | Maytag MGR5755QD CleanDesign Gas Kitchen...
MY MAYTAG OVEN WILL NOT TURN ON WHEN I SET THE ELECTRONIC DIGITAL THERMOSTSTAT LIKE SAY I PROGRAM IT TO 350 DEGREES,,, NOTHING HAPPENS,,, BUT WHEN I GO TO SET THE BROILER THE BROILER WORKS JUST FINE,,, I...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
Dec 30, 2010 | Maytag Ovens
I recently bought a used Maytag gas range model #crg9700aaw. I am having an issue as the lower gas burner in the oven will not ignite. The broiler turns on and works fine, all the burners work fine as...
I had same problem, same model. Twice in 4 years. Was the lower ignitor gone bad. First time I assume to old age. 2nd time wife overloaded a roaster pan and it overflowed during cooking, and got liquid/**** on the ignitor somehow and killed it.
New one is $43 (http://www.repairclinic.com/Shop-For-Parts?s=t-crg9700-%3d%3d) online. More like $65-75 locally.
Tip: Upper (broiler) and lower ignitors are identical. For a quick test: Swap out the top one to bottom position and see if it works.
It has just today happened AGAIN to me 7 months later. Hence my being online for this.
It's an old horse, and 2 burners up top are acting funny for some time now. Rather than throw more good money into it I think I may trash it and just buy a new stove.
Nov 24, 2010 | Maytag Kitchen Ranges
I have a K/A kgst307 gas stove that was bought new as a natural gas unit. After 3 years, I moved to a house that had propane. NO PROBLEM because an LP conversions kit came with the stove. Used the stove on...
Although the natural gas orifices for the stove top burners were replaceable with propane orifices, many ovens/broilers orifices are simply adjustable using a 1/2" open end wrench to convert from one gas to another. Some brands are adjustable and some have to be changed out. It depends on the make and model. Do you have your owner's manual? It contains detailed info on converting your unit. I included a link below to choose from the list to download your manual. You'll need your exact model # listed on your stove. Pull out the bottom drawer and look at the data plate for the model # and then find it on the list for the correct manual. Douglas
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KGST307&siteCd=WHRCOM&userType=Consumer
Oct 01, 2010 | KitchenAid KGST307 Gas Kitchen Range
Oven won't work. Maytag Performa Stove. Broiler and burners work.
sounds like your bake element is gone
but the model number would help a great deal
pul out the stove unplug it, take off the back, and inspect the connections on the bottom element
if its gas its probably your ignitor
take out the racks
take out the bottom
set to bake
you should see a very bright light within a minute
if you dont thats the ignitor
anyway both parts are available
and both are a pretty starigt forward repair
Oct 09, 2009 | Maytag Performa PAV2200
Maytag gas oven quit working
Sounds like the ignitor is bad. They get weak and stop opening the valve completely so it may cause the gas smell.
Sep 02, 2009 | Maytag MGR5729 Kitchen Range
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Bad smell coming from stove
Look In broiler compartment and check for signs of mice
Apr 06, 2009 | Frigidaire FGF378AC Gas Kitchen Range
Clicking sound on my gas stove
there switches behind each knob, 1 of them is broken,or wet, when you remove the knobs then remove the knob panel you can test them and find the bad one,they are no more then $15.00 each. to test you can plug the stove and disconect the switches one at a time until you find the bad one replace and you are back in bussines.
Dec 11, 2008 | Maytag MGR5770 Gas Kitchen Range
Maytag 30" Self-Cleaning Freestanding Gas Range - White Logo
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
